Help my Aussie!!
Started by Sparkplug, January 31, 2008, 04:23:45 PM
Sparkplug
I got my aussie, and pulled axles, and have it down to carrier. I cant get the roll pin out tho. I tap and tap, but it only goes so far, then stops. Do I need to hit harder? What is going on? Please help. I have gotten everything else off no prob, even ring gear, but now im stuck. Help please
skid
The carrier is usually staked so the pin won't come out on its own.   Sometimes alot of force is needed to overcome it.  Have you tried tapping it out the other end?
Just to make sure, your talking about the roll pin retaining the spider gear cross pin?
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
drill a small portion of  the hole  to ease removal
Sparkplug
Yes, im talking about the rollpin, that holds in the shaft, that holds in the spider gears. one end is a lil more closed then the other, so im tapping it from that side out. I have 2 different sized punches, and I think ive whacked on it pretty hard, but maybe I need a bigger hammer. 79, is it really ok to drill part of the hole out, how far down should I go? Im gettin desperate here plz help!! Thanks
MiniSimp
Hit it from the other side dumbass. It only comes out one way.
And make sure your ring gear is off.
http://gearinstalls.com/bill.htm
Sparkplug
lol, harsh, but I found it out on my own thanks
werty
Sparkplug
Got it all back together, need to torque ring gear and cap bolts, then its back in, Ill post up how it performs on the road, and thanks for the help.
Doof
make sure that you have your :pokinit: set right and when you test it do slow
