I have a 94 truck with a 22re and code 52. This is a knock sensor circuit or pcm issue. I need a new sensor, the connector is busted out of the sensor. On to my questions, I have a 91 with a 22re, will this knock sensor work? I talked to a toyota parts guy today and he said that 92 to 95 would work but I don't think he looked to see if the part numbers between a 91 and 94 would be the same. I am also getting a code 13, now I'm planning to put in the new knock sensor and see if this clears up both issues, if not any tips on where to start or known failures that could cause this? I haven't investigated code 13 at all yet, I'm going to look in the 93fsm online and see what it has to say.
Thanks
Andrew
