air tank from arb locker compressor?
Started by 79toy, January 19, 2008, 07:58:41 PM
79toy
i dont know much about air compressors.  has anyone done this?  i know how to do it i just dont know if the compressor would be able handle it.  sorry for the newb question.  please post up pics if you have a similar setup.  thanks
CTENG in KS
You can, it just may be slow to fill.  I do not know what the CFM rating for the ARB is, but it likely isn't a lot.  You might be better off running the ARB compressor and another electric pump feeding into the same tank to have some useable air on the trail.
79toy
thats what i was thinking.  i got a homebrew setup coming straight out of the arb right now but i want an actual tank so the compressor isnt running forever.  this is where i got the info for my setup.  http://www.links4jeeps.com/writeups/arb_inflator/
CTENG in KS
Hard to make out, but it looks like the rating on the comp in those pics is less than 1 CFM.  This is not going to fill a tank bigger than 1 gallon very fast to any measurable pressure.  If you wanted to set up something like that write up I would def go with a second compressor.  There are a few out there sub $50 that would be easy to run alongside the ARB into a small tank.
Hottrod81
79toy
i believe its the older model that came with the lockers. model RDCKA.  i dont think ARB sells them anymore.  not too sure.  what compressor/tank setup do you think i should go with?  what are you guys running?
79toy
79toy
how does this compressor look to use with a tank for OBA?  if i get this compressor i want to get rid of the setup i currently have on my arb compressor.  also what size tanks are you running and where are you guys mounting them.  thanks
http://www.4wheelparts.com/PDT264903.aspx
CTENG in KS
TOO much money, there is one that is rated just as well much cheaper.  Hold on, I;'ll find it.
CTENG in KS
http://www.amazon.com/Q-Industries-MV50-SuperFlow-Compressor/dp/B000BM8RT8/ref=pd_bbs_1?ie=UTF8&s=automotive&qid=1200930130&sr=8-1
This one has gotten good reviews and testing has shown it to be comperable to the viar units.  Only 12v compressor that get significantly better ratings is the Oasis...$$$$$$$
79toy
nice find.  after you posted that i did a search on pirate and found that they sell the mv1050 compressor for fairly cheap as well.  i believe it is 2 mv50 mounted together.  im definitely going to look into these.  thanks a lot.
red
what cfm is an ac compressor at? thinking about doing that with my blazer
read and comment :whip:
USAF EOD tech
skipnrocks
Can you run your locker off one of those co2 tanks?   Might be more simple just to get one of those?  Sorry if its off topic.   Or  another thing is the new motors on the some compressors are oiless put out a ton more output and are the size of  vcr.  I dont know if you can buy the compressor motor by itself.
WILLYNILLY
CTENG in KS
The MV50 puts out 2.something CFM, not sure at what psi though.  You can run lockers, etc off of them.  With the right size tank small air tools in short bursts are possible.
My personal opinion is to set up some on board system over the CO2 tank as it is unlimited supply.  I hate having tanks filled.
skipnrocks
What about one of those pancake compressors and a small inverter?  fairely inexpensive, you could seperate the motor and mount it in the cab, then run a hose to a tank?
WILLYNILLY
79toy
Quote from: CTENG in KS on January 21, 2008, 10:59:23 AM
same here.  i was thinking about going with a 5 gallon tank mounted underneath the bed. well see how it goes. info
CTENG in KS
Quote from: skipnrocks on January 21, 2008, 11:16:19 AM
Depends on the compressor.  Don't forget, a 15amp ac compressor is gonna need MINIMUM 1500W inverter to have a prayer of running.
skipnrocks
Thats doable,  I think the air output would be enough better to merit the expense doesnt seem like those little auto ones do much!
WILLYNILLY
Rockcrawlintoy
Quote from: skipnrocks on January 21, 2008, 10:31:54 AM
i run my arb on CO2 its been about 5 years and i still have a good bit of co2 in the tank. i like the co2 because it cant fail other then notkeeping it filled
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
skipnrocks
WILLYNILLY
CTENG in KS
Quote from: Rockcrawlintoy on January 21, 2008, 01:16:54 PM
This is a great strategy if you are not using the air source to air tires back up.  I usually need to put 10 #'s of air or so in before I get off the trail so I would rather have a renewable source.
skipnrocks
That was my concern with 42s that I would be using uup the co2 tank too fast.
WILLYNILLY
Rockcrawlintoy
Quote from: CTENG in KS on January 21, 2008, 01:31:51 PM
yeah me too i am goin to be hookin up a york soon and keeping teh co2 for the arb
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Yota4life
Iv been running the MV50 comp. for almost 2 years now. Hard mounted under the hood and plumbed to a 2.5G tank. Run my arb and have aired up my tires to many times to remember. Still running strong!
Huhwhye
#24
I just bought an ARB for my front diff, getting it installed hopefully in the next week.  Looking for suggestiion on how to run it.
Is there a concern with compressors that it will put moisture in the oil over time?  I know the big compressor in my garage builds up water and needs to be drained occasionaly.  Do people use moisture separators?
Also, don't CO2 tanks hold like 1500-1800psi?  I have a 20# one on my kegerator that has fed 6 kegs and still has 1300 in it.  It's been so long I don't remember what it was like full.  I bet it could fill a lot of tires no matter the size and still have plenty for the locker.  Cost less than $20 to get it filled or exchanged.
'04 Taco DC 4x4
