87 Transfer Case
Started by TigerToy, June 13, 2004, 08:41:55 PM
TigerToy
Will an 87 T-case from a carb motor work alright in my stock 82.
84runner
are you talking as a stock replacement or for dual cases ?
just fine if you change the shift rods.
84runner
Ya I could of told you that I guess instead of asking a stupid Question  :smack:
It will work as WT mentioned if you change both shift rods and the low range shift fork, but be sure to use your 82 T/case gasket because 84+ transfercases are slightly taller and use a larger gasket that will not work on your L-series transmission..
Good luck
