Injectors?
Started by SWAMPER, June 12, 2004, 11:27:37 PM
SWAMPER
Hey guys posting this up for a buddy of mine....he has a 1986 4Runner and has some lil mods on the engine he was thinking of changing his injectors but he dosent know if aftermarket (better than stock) will flood his engine? :wave:
Prismo
All in all I think I would leave them stock, just have them rebuilt if they are failing. I think RC Engineering was the place I used.
SWAMPER
Are the ones from RC engineering like the stock ones? (are you sure its not LC engineering?) :beer:
84runner
Im pretty sure He ment LC  :yupyup:
Prismo
I am almost certain it was these guys. LC does carry them too. Check around the web for the best prices.
http://www.rceng.com/
brainlessfool
"over sizes injectors" sould not flood the eng. it contoled by the computer. if it's rich it shortens the time the injector is open. I'd just stay with a stock replacment.
Quote from: brainlessfool on June 15, 2004, 09:08:05 PM
This is not true. The computer can only pull the fuel back so much and then it will just run rich. Anything more than 15% or so larger injectors should run richer then normal.
Hey LILSWAMPER, What mods has your friend done? If his engine is requiring more fuel, then Im sure he's done a whole hell of alot of mods..
If he just wants it to run a tad bit richer, try the AFM fuel trick if you dare.
SWAMPER
I think he has a carb...and the KNN air filter dont know what else he has. ???
If he has a carb engine then he does not have any injectors!! He should increase the size of his jets in the carb or for starters just try increasing the float level-
SWAMPER
Sorry I messed up I dint mean carb :smack:....I meant something else :smack:...i dont know It was too early  :headshake:
Prismo
Look in Blucruz's engine thread. He posted a link for rebuilt injectors he says are cheaper than RC's. ;)
brainlessfool
 :headscratch: hummmm so the puter will only comp. for about 15%? thats all? man that's not much. thanks for the onfo mike!
