When I filled the diff I could only get 2qts in. Thinking I need to lift the rear up quite a bit to get the last 1/2qt in. What have you guys done, makes sense to me .
As far a the rear goes just remove the axle vent and add the rest of the gear oil through the vent hole.
That sounds really tedious and time consuming.........almost like.....Not really, goes right in, the oil that is.WORK
You can drive around in 4H with hubs unlocked, This will break in the drive side, than you can drive in 2wd with hub's locked to get the coast side. As far a the rear goes just remove the axle vent and add the rest of the gear oil through the vent hole.
That sounds really tedious and time consuming.........almost like.....WORK
I'd be careful driving around town with the hubs locked even in 2wd, the front tends to get hotter than the rear and will start spitting gear oil out the vent tube which means it's getting a little too hot.
not to say this the right way but i never even broke mine in haha. if your really consered take your inners and birfs out and drive it around in 4wd for a month. only if you have a good drive line though
This is how my gear guy told me to break mine in. He goes by Gearman on PBB and is one of the best in the USA.Me-How do I break these gears in?Gearman-Where are you going?Me-Con (Rubicon).Gearman- By the time you get to the Box (Little Sluice) they will be broken in, then he smiled!!!!!Well that is what I did about five years ago and they are still going strong.
Started by Drachota Parts For Sale
Started by Bazzi Project Research and Build-Ups
Started by yotakid707 Toyota Pickup/4Runner Tech 1979-95
Started by TWP PREZ New Member Check-In!
Started by schadenfreude « 1 2 ... 5 6 » Axle/Differential/Steering
