Tundra Axle
Started by Jagdverband44, January 04, 2008, 06:42:54 PM
Jagdverband44
       Does anybody know the specs on the new Tundra's silly big rear axle. I freaked out when I saw one because the thing looks like a 9'' Ford. The 8'' rear is about as strong as a 44, but this new axle looks sexy. I am putting on my list as a potential swap if I can get a hold of one...one with the Elocker   :beerchug:
I've got the most liftedest truck in town, that little jap truck done stand no chance gainst my Chevy. My Chevy gots a V8 more lift an bigger tires,and an exhaust system, whats yer tuna can got, a V4, and them tires look like they is offa Saturn Corulla. The dealer instulled my lift, so ya no its done right, you just try to foller me throo them rocks an see what a reel truck can do.
DTB
94MtnYote
Quote from: DirToyBoy on January 04, 2008, 06:46:49 PM
10.5" ring gear!  :yikes:
Indeed, 36 spline axles,with an outside diameter of 1.457 nches comparable in strength to 14 bolt or Dana 70, so says the august edition of 4wheel and off road.
Marlin 1200LB clutch
AaronB
now to find a match for the front.
94MtnYote
skipnrocks
Quote from: toyoduh! on January 04, 2008, 07:36:51 PM
I read that too I think that they must have been comparing ring and pinion cause the 14b has a 1.5in shaft and is something like a 20% differance in strength according to pbb.  Anyways not the point just something that seems to be odd to state cause shaft comparision would put it closer to a 30spline d60 rear.
WILLYNILLY
red
Quote from: skipnrocks on January 05, 2008, 07:27:11 AM
x2
read and comment :whip:
USAF EOD tech
bigarms23
for a front housing have a diamond made to match the rear axle of a new tundra
Gittinit
Quote from: bigarms23 on January 05, 2008, 12:59:45 PM
X2 diamond with tundra center section and kingpin knuckles. Oh beef! :chew: yum yum yum
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
AaronB
Quote from: Gittinit on January 05, 2008, 01:11:20 PM
Heck yeah, Ill be in line for that.
Jagdverband44
 Tell ol' Marlin to whip up a tundra  high pinion 3rd with fj80 knuckles  ? I really like the closed knuckel design.
big ron
what are you going to do about the lug pattern? the new tundra is a 5 lug.
skipnrocks
How come tundra went from six to five lug, is six over rated?
WILLYNILLY
big ron
Quote from: skipnrocks on January 12, 2008, 05:26:18 PM
couldn't tell you.
Gittinit
I wonder what the advantages are to running the 5 lug on this axle? Most comparable axles run 8 lug, which I'm shure is overkill for the application.
my favorite places:
red
5 would be a disadvantage, harder to get wheels in the aftermarket for one thing
USAF EOD tech
Ramrod
ya im pretty sure that nobody is making rims for the new tundra yet, its some wierd 5 lug pattern
DTB
Quote from: TEAM RAMROD on January 13, 2008, 12:03:24 PM
thats gay
surely toyota designers have something up their sleeve that we dont know about
Toymin8r
They switched to a metric lug pattern but I don't know why they went to five.
skipnrocks
Quote from: toyminator2000 on January 13, 2008, 01:39:04 PM
just to give us something to talk about!!!   LOL
WILLYNILLY
ZukIzzy
No real Lockers availible yet. We are working with Toyota to get a couple thirds to Brian @ Diamond so he can build one and possibly start producing them. We are also working to get a locker produced for them.
Axle shafts are really close to 35spline major diameter with a slightly larger Minor diameter. Ring gear is really close to the same  as the 14bolt and again similar size major and larger minor diameter. The whole thing weighs about 100 lbs less than a d60 rear. It will be a great axle but there is much work to do.
Wayne
94MtnYote
Supposedly arb is working on a locker for the new toyota 10.5". :dunno:
ZukIzzy
Quote from: toyoduh! on January 14, 2008, 01:32:09 AM
Eaton as well, to me it looks like proper machining on an existing locker blank but to the big guys it is a much bigger deal.
Wayne
skipnrocks
Does it have a stamped housing or is it cast of some sort?  will it be easy to shave?
WILLYNILLY
ZukIzzy
Quote from: skipnrocks on January 14, 2008, 08:07:31 AM
Stamped same as 8" toyota or 9" ford but BiGGER
skipnrocks
Cool,  may have to check one out.  Think I still want portals though.
Wonder how much you can shave?  I know if you try you can get 2in off the 14b.
WILLYNILLY
