New cooling fan install
Started by Doable, January 02, 2008, 06:40:46 PM
Doable
1st thing was to get the the old fan and clutch assemble out the way.
Then make some "L" brackets to attach the electric cooling fan to a 1984 metal shroud
Nothing puts a smlie on my face like the green glow of 4x4 on the dash !
BSLCA.com
Doable
The fan was from a Suzuki SideKick
then tighten the four angle brackets
Here is the fan/shroud bolted up to the radiator
This is what it looks like from the top looking down and the clearance between the engine.
BSLCA.com
DanS
Great Idea with the metal shroud, let us know how it works  :thumbs:
DanS
Wow, been looking at my 4Runner rust away too long, need some inspiration and here I will find it...!
85 Toyota 4Runner, solid axle, 22Re, original paint and graphics and not a straight panel to be found!
looks a little on the small side..........
:confused:
Doable
Quote from: emsvitil on January 02, 2008, 08:24:20 PM
:confused:
?? I'll have to measure when I get home but I think it's the same O.D. as the factory one I took off not sure though.
BSLCA.com
metal shroud? where did you get that? my shroud is a pos piece of plastic
Doable
Quote from: jimbo74 on January 03, 2008, 10:45:28 AM
I don't know how to look it up or get a part number, I'm sure some one on here has the knowledge to find it but all I remember is that It came off of a standard cab Toyota 4x4 that I bought a few years ago.When I parted out the truck it was one of the few parts I kept
BSLCA.com
Quote from: Doable on January 03, 2008, 10:40:39 AM
I'll rephrase.....  looks small because of the gap in the shroud.       The shroud doesn't do anything with a gap like that.
i agree it doesnt look right, the factory fan is a lot bigger than that electric, it fills the shroud. i almost couldnt get my shroud over the fan until i realized there was a cutout on the bottom that bolted in
RN37DD
looks good. I'm running a free 3 core now off a 90's truck.. 2 core on my 79 was gone. had to mount it back towards the engine 1/2 inch to keep it from hitting the hood. a little close to the engine so i broke the plastic shroud in a fit of get it done.  :willynilly: anyway put the 79 metal shroud on.. bolted right to the newer rad. yes there is a gap but the motor runs very cool.
Thomas P
i wish i had pics of my elec fan and shroud, but i made a piece of sheetmetal cover my entire radiator and then cut out a hole the same size as the fan, and it is the most efficient shroud possbile, oh the fan was off a newer chevy truck and spans nearly over all the cooling fins, this thing cools like a champ, also on a new 3 row radiator
'14 Camry SE
SCX10 Honcho on roids!
Doable
Quote from: emsvitil on January 03, 2008, 02:04:24 PM
I measured the electric fan and it's 13 1/2" the opening in the shroud is 17". I understand your question now and see  :hammerhead: that it will not be the most efficient.
:crossed: that the radiator is for a automatic and a little larger than the one with a standart transmission that it will still cool the engine.With an opening like that later on isn't a 16" the next standard size?
BSLCA.com
Thomas P
ditch the shroud, buy a piece of sheetmetal, cut out a hole, bolt fan to it  :twocents:
'14 Camry SE
Thomas P
'14 Camry SE
Quote from: 1985efiyota on January 03, 2008, 07:02:53 PM
your fan is big enough
the test is summer time with the AC on..............
I'm using a 16" for my 86.
Thomas P
i just measured mine its 16" too........
'14 Camry SE
