Author Topic: Seafoam in a 22re  (Read 5782 times)
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
Seafoam in a 22re
« on: Jan 02, 2008, 02:37:14 AM »
Alright, I figured I would try out this seafoam stuff for the first time in my 22re. I plan to do it like the way this guy did. http://ls1tech.com/forums/showthread.php?t=534376 I was just wondering if there were any pointers, or anything I should be aware of before I do this. Where should I suck it in when it comes to that point? The brake booster? Or PCV? Can I damage anything? Should I run normal low grade gas when I do it? Thanks for any replies, I searched and got a lot of info, just not exactly what I was looking for.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: Seafoam in a 22re
« Reply #1 on: Jan 02, 2008, 02:53:47 AM »
brake booster, also send some down the throttle body
i dont quite get the pcv as that will dump it into the crankcase and that wouldn't be good....
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Jan 02, 2008, 08:34:56 AM »
you need to suck it in thru the intake,  as close  to the throttle body as possible
then  pour  some (maybe half)  in the gas tank,  so it will go thru the injectors
« Reply #3 on: Jan 02, 2008, 08:42:54 AM »
brake booster thing  is  ok  for a  camaro  but  not  a 22RE
and remember  a camaro gas tank is  probably  a good bit bigger than yours
and a camaro uses  91 grade,   your 22re  runs on 87 or 89,   so NO  you dont need  to use 91 grade gas
  • Male Posts: 8,707
« Reply #4 on: Jan 02, 2008, 08:44:46 AM »
what is wrong with sending it through the brake booster on a 22re?
i havent dont it on an re, but i have put it through my brake booster on my 22r and all the otehr cars i have ever owned with fuel injection
fordh8r
  • Turtle Points: 850
  • Male Posts: 2,588
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
« Reply #5 on: Jan 02, 2008, 09:14:22 AM »
Being only a 4 banger you'd be lucky if it could stay running with that big of a vac leak.  Then try pouring something in it that will make it misfire at the same time. Good luck with that.  :crossed:
« Reply #6 on: Jan 02, 2008, 09:23:22 AM »
because  you'll only be cleaning  the  inside of the head  ,  and the bottom of the intake,  and  the BIG vacuum leak  will likely  kill it
puting it thru a vacuum port near the  throttle body willclean the entire intake  and plenum,  along with the head
KDXSR5 [OP]
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #7 on: Jan 02, 2008, 12:19:40 PM »
All the vacuum lines near the throttle body are real small. Do I just rig up a funnel to one and pour? If I do it this way, I wont have to use the deep creep stuff. I pour half near throttle body, half in gas tank, and half in oil like 100 miles before I change it, correct? I really don't want to do something bad to the little engine, bit it has a few problems that I hope this will fix.
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
« Reply #8 on: Jan 02, 2008, 01:08:53 PM »
Pour 1/2 the bottle in your tank, then find the most forward vacuum port on the throttle body & remove the hose. Get a long enough vacuum hose the same size & connect it to the throttle body & drop the other end into the bottle & start the engine, it should suck in the Seafoam  :twocents:
87 4Runner redo
« Reply #9 on: Jan 02, 2008, 06:41:35 PM »
:werd:
Tice
  • Turtle Points: 8
  • Male Posts: 881
  • Member since Feb '05
  • I named my son Wheeler!!!!
« Reply #10 on: Jan 02, 2008, 07:08:53 PM »
Sorry for the hi-jack, but what does this stuff do (clean I'd imagine) and where do you guys get it from?
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
  • Male Posts: 8,707
« Reply #11 on: Jan 02, 2008, 07:10:57 PM »
you can get it pretty much at any auto parts store
KDXSR5 [OP]
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #12 on: Jan 02, 2008, 07:11:05 PM »
Its ok, at least you are not talking about a totally different subject. It is a decarbonizer, among other things. It cleans out your engine, and if I remember right, it is 100% petroleum product. You can get it at any autoparts store like NAPA and checker and autozone, like jimbo said.
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #13 on: Jan 02, 2008, 07:14:38 PM »
Thanks! :beerchug:
Last post Apr 06, 2014, 01:18:42 PM
by kneedownnate
Last post Oct 10, 2006, 11:56:50 PM
by BLACKDOG
Last post Mar 03, 2007, 04:06:19 PM
by Tallchevy
Last post Mar 26, 2007, 01:36:56 PM
by Cheesemaker
Last post May 16, 2007, 11:23:31 PM
by SACD_Runner
