question about high pinion diffs
Started by toyo487, December 31, 2007, 08:08:22 PM
toyo487
This is probably a stupid question but can I take a V6 diff and make it into a High Pinion diff by installing revers cut gears and the proper oil slinger and parts? or is the high pinion diff completely different from the V6 diff?  The part # on Marlins web is the same for both the V6 and High pinion diff.  Thanks, Justin
1986 Toyota 4Runner 22re 5spd transmission and dual transfer cases (4.7's in the rear). E-lockers front and rear.
2005 GMC Sierra diesel, compound turbo setup to pull.
   God gave all people talents but the only one who can find them is you.
bearings are the same thats all
so  to answer your question  NO
