Transmissions
Started by Rubijon, December 27, 2007, 10:10:25 AM
Rubijon
What is the difference between the W56A and the W56B
MiniSimp
W56-A Transmission
With the introduction of fuel injection in 1985 4WD trucks, Toyota also introduced it's new W-Series transmission. The W56-A was only used in 1985 EFI Toyota Pickups and 4Runners. W56-A models have an aluminum center plate and a single shifter (transmission) atop it's rear housing. This transmission is 25 3/8" long and weighs 85 lbs as pictured. The center of the trans shifter is 21" back from the front edge of the bell housing.
Years used: 1985
W56-B Transmission
The W56-B was used on 1986-1988 EFI Toyota Pickups and 1986-1989 EFI 4Runners. This model can be identified by having both a cast steel center section and a single shifter. This transmission is 25 3/8" long and weighs 85 lbs as pictured. The center of the trans shifter is 21" back from the front edge of the bell housing.
Years used: 1986 - 1989
Rubijon
I have an 85' pickup (carb) and I need a new Transmission which trans should I buy. W56A or W56B.
MiniSimp
Quote from: Rubijon on December 27, 2007, 10:29:25 AM
Either way, they are both good. Have you thought about having Marlin rebuild yours?
Duffil
Quote from: MiniSimp on December 27, 2007, 10:40:46 AM
an 85 carb should have been a G series.
Rubijon
Quote from: Duffil on December 27, 2007, 02:04:53 PM
The guy I got this truck from said he changed the transmission. Now that I am going with dual cases I pulled the t case and part of the trans came off with it. It was JB welded on. I want to strangle the guy I got the truck from. Now I guess I need to figure out what transmission to go with.
Duffil
oooh broken extension housing.  Check on the MC trans page to be sure of what is under there now.
Rubijon
From what I can tell There is a W56 I have not got it out of the truck yet I am going to start in about 30min. I dont know if it is an A or B
MiniSimp
Why don't you call Marlin and see if they have the part you need to fix it.
Rubijon
I have been trying to call Marlin and I get no answer. Did they change there #. I call the # off the web site and some lady answers the phone.
MiniSimp
Quote from: Rubijon on December 27, 2007, 02:35:09 PM
Same number 559-252-7295
Rubijon
Yeah I just talked to John at Marlin I definitely Have a W series Trans. I need to figure out how to dial the phone. :hammerhead:
red
the w56a and w56b are interchangeable with no modifications, when i replaced the w56b that went bad in my 87 4runner (bearings) i used a w56a from a 1985 4runner, bolted right up with no problems or modifications.
read and comment :whip:
USAF EOD tech
Rubijon
Rubijon
pulling out the transmission is a pain in the ass
TIMS89CRAWLER
Quote from: Rubijon on December 28, 2007, 07:40:10 AM
yes sir it is
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
Rubijon
It was not as bad as I thought. :dunno:
Plekto
My favorite method that I have seen to remove it is the 2x6s and straps and lowering it.   But, yeah, it's not a terribly hard thing to take apart.
Redbeard1
I just pull them and stab them by hand they only weigh about 90#.... unbold it get ryt under it with a creeper put it down on your belly and roll out.
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
Rubijon
I guess thats one way of doing it.
