Axle differences...
Started by Hammerhead, December 21, 2007, 10:45:58 AM
Hammerhead
It's time to build another hybrid rear axle and I need to widen things up a few inches and would like to do it without spacers.  Nothing wrong with spacers, I've been running them for years with no trouble, I just would like to build a bit wider if possible.
I understand that the Taco axle is about the same as the prior axles except wider.  I know it has the same 30 splines on the drive axles.
What I need to know is; Does the Taco rear axle use the same wheelbearings and flanges as prior years?
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
toy4x4ota
LIFTED TRUCKS ARE GAY
DeadlyPeace
I believe that everything that is attached to the axle is larger. Bearings, seals, and brakes. Not sure about the brake cylinders. They are inner changeable, but not sure if the bore is the same on them. The bolt pattern/size on the flanges I think are the same though if that helps.
I have the longer axle on my TOY and a spare shorter one at my shop. I can see about checking these out for you this weekend while I'm there. Let me know.
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN
Never let people think you're a horrible person and always keep the heart of a young child...
       ...I prefer mine in a jar on my desk.
3 CAT scans a MRI and some time with the shrink and it's comfirmed. I'm just not right in the head.
Global Moderator for www.ToyotaOffRoad.com
Hammerhead
#3
Does this mean that the Taco drive axle assembly (wheel bearing, flange, brakes and all) would slide right into and bolt up to the same axle housing end flange that is on a '79 through '85 mini?
'88 X-cab, V6
DeadlyPeace
It would except for the axle being longer so it wouldn't go in far enough to be able to bolt it up.
Hammerhead
Cool, the length doesn't matter since I build my own housing anyway.  I can set the width wherever I want it to match the width of the drive axle assemblies... 8)
Another question:  Does the newer runner have the same width axle with disc brakes?  I'm thinkin' rear disc brakes would be a good thing... :yesnod:
'88 X-cab, V6
