Welding on a new shifter?
Started by skipnrocks, December 14, 2007, 06:10:47 PM
skipnrocks
I dont know if any of you have noticed but my shifter is super short. . well I cut it off because it was the wronge shape and kept hitting the dash... I was going to get a piece of pipe and bend it to the shape I wanted and then weld it to the stub, and then cross drill and weld plugs in.... Is there any issues here?
The other thing I was concidering was using solid stock and welding it on in place, and then welding a sleve to protect the joint....  I tend to thing the solid will be easier because I dont have to worry about kinking or flatening when I shape it...
WILLYNILLY
If you use thick enough wall tubing you won't have to worry so much about it bending.  You could maybe use tubing that'll slip over the stock shifter shaft, drill several rosettes in the top and bottom, then weld the bottom to the existing shift shaft and slip the top few inches of the stock shaft into the top of the tubing and weld it in.  Shouldn't have any strength issues there, but I'm no metalurgist (sp) :dunno:
DTB
I would use galvanized sign posts
and duct tape
:biggthumpup:
skipnrocks
Quote from: DirToyBoy on December 16, 2007, 05:48:46 AM
and duct tape
:biggthumpup:
you would wouldnt you!!!!
LOL
WILLYNILLY
I shake and convulge every time I get near that stuff :shudder:  Something about me, a motorbike and high speed + galvanized sign post make nathan lose memory :headscratch:
twistedtoy92
lol yeah, im a nathan as well and my head doesnt like galvanized posts either!! makes me cringe.............   :hammer:
Did you kiss one at a high rate of speed too?  Or, like me, do you not remember doing it :haha:
TIMS89CRAWLER
just weld the top back on and grind it smooth.... i do it on every rig i own.....
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
BLACKDOG
  Had to cut and raise my to clear the body lift, and the other shifters for my duals.  I just cut it, cut some small dia. pipe in half longways, and welded the cut sections of the shifter into one half of the pipe the way I wanted it, then used the other half to cover it and welded that on as well.  Worked great, no problems at all :thumbs:
pics here
http://board.marlincrawler.com/index.php?topic=23424.msg278519#msg278519
              -Ronald Reagan
twistedtoy92
Quote from: kneedownnate on December 17, 2007, 09:03:42 PM
well i think it hurt....... and i still have a goose egg on my head!!!!!
skipnrocks
Quote from: BLACKDOG on December 17, 2007, 10:42:02 PM
pics here
Thats not a bad Idea.
WILLYNILLY
