The following is on my '95 V6 4Runner w/ the R150F 5-speed w/ 194k miles.
I've got my transmission out to replace a stripped coupler and input gear on my t-case and figured I would replace the clutch while it's all apart. I noticed that the pilot bearing was a bit clicky when I spun it after pulling the flywheel, but didn't think much of it since I would be replacing it anyway. However, upon inspecting the transmission input shaft I noticed that the end of the shaft (where it goes into the pilot bearing) is worn down. I put the new pilot bearing on it and it's definitely not as snug a fit as it should be. So, I guess I should probably replace the tranny input shaft while I have the transmission out or else this could cause some problems down the road. Now for my question:
Can I simply unbolt the cover around the tranny input shaft (inside the bellhousing), pull out the input shaft, and pop in a new one? Or do I need to tear down the whole transmission to replace it, at which point I might as well do a complete rebuild? I'd rather avoid the rebuild since I don't drive the 4Runner much at all, only to 4wheeling events and on rare occasions around town, probably only between 1k and 2k miles per year and the transmission hasn't been exhibiting any problems really (no popping out of gear, no noticeable noise, etc.).
Thoughts? Ideas?
