with all the rust and corrosion you better have some new lines handy when you try and move thatand yea just unbolt the bracket from the frame, drill a hole somewhere further back and use some self tapping bolts,personally i would run that thing up front and use a cooler from Summit Racing,
I used some studs and spaced mine away from the shackles....has worked well.
My Toyota is a 86 auto . Since I do not have A/C I was able to put a Fluidyne Extra Heavy Duty Transmission Cooler up front behind the grill and used the cooling line going to my radiator to feed it. I bought of Ebay it cost $34.00 delivered. It seems to do the job for me.
that cooler is HUGE! do you notice increase in engine temps? its blocking like half the radiator
Blocks less then an AC condenser does.Check out the front of a CTD Dodge 2500 Ram, AC condenser, oil cooler, tranny cooler, intercooler, and radiator. Cools fine,
Started by sams Parts Wanted
Started by jmadamo Project Research and Build-Ups
Started by Jason Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by Addicted Offroad Toyota Pickup/4Runner Tech 1979-95
Started by mmessier2 Toyota Pickup/4Runner Tech 1979-95
