How do you remove Rhino Lining ?
Started by Skim, December 05, 2007, 09:20:54 PM
Skim
85 Hilux Long Bed - For Sale
toyotanner
i used to work in a rhino bay and as far as i know you can only pull it up so get out your scrapers. probably a like 2 inch wide stiff putty knife and a box cutter :thumbs: one time i had to pull rhino lining out of a ford bed in the sun it seemed to be a little easier when the bed liner was hot
Motorvated
dont..it wont come off of your hootus lol
86bobbedtoy
well its only thinner is xylol, that might work.
A really hot thiner might also work.
Its oil based thats what makes it hard.
I had to remove some and paint stripper works great one spray or brush over it and five minutes later ready to spray off.
If you got it on your hands Id suggest hot water and Xylol.
Good luck.
Plekto
The problem is it's toxic in the extreme when you apply any solvent to it and the dust is almost as bad.
So you don't unless you have all the gear(think car painting setup with respirator).
HARJOMOTORSPORTS
Quote from: Plekto on December 06, 2007, 03:35:10 PM
Also, you might try Aircraft Remover. That stuff is nasty too... don't breathe it in!  It softened most everything I've used it on like paint, bondo and epoxy, enough to scrape off.
:twocents:
Scott Harjo
HARJO MOTORSPORTS
Rockcrawlintoy
get a bunch of dry ice and freeze it and chip it off
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
DTB
DN1911
a very good respirator and a big grinder.
i helped strip a jeep tub one time, we used big chisel, scrapers and a lot of work with a small dead blow hammer. after you get the majority of it off a good wire wheel on a 4 1/2" grinder will finish it off. i would avoid using any chemicals on it.
skipnrocks
WILLYNILLY
Plekto
#11
X2 the more on top.
Actually, I'd just get a new bed and save myself the environmental and chemical damage.
EDIT:
After looking online and finding tons of "it's impossible" postings, the consensus is that you need to find a place that has a sandblasting setup that's sized to do the entire truck bed/cab/etc.  It's usually a giant tower and they run it in this enclosed space for 30 minutes or so.   Everything comes off.
Any other option just won't work or will literally take like 50-100+ hours.
skipnrocks
I guess thats a testimony to their product....
Again are you taking it off cause of flaw or just dislike?
WILLYNILLY
