Need help with auto!
Started by superstarai, June 02, 2004, 02:42:44 PM
superstarai
 Hello i was wandering how to switch from auto to manual easy or not? I want to put an 85 5 speed with dual t-cases and dual stick in the second case any info would be great i have a 85 toy e-cab pickup with a 22re non turbo and anybody with 85 5 speeds and t-cases that they want to sell for a decent price and willing to ship let me know thanks guys.  :beerchug:
Its really easy to do the swap, it just takes a bunch of parts.  Youll need at the minimum, pedal assembly, clutch master, pressure line, slave cylinder, flywheel, clutch set, and a butt connector to bypass the neutral safety switch.
superstarai
   So the drivelines dont need nothing? It sounds like a great thing to do thanks for your help.
Nope the drivelines dont need anything.  The front output is the same diseance from the face of the bellhousing but the rear is about 1 1/2" shorter so youll have a bit more slip showing on your rear driveline but it is not a problem.
superstarai
 okay coo,l do you know how long it takes? I cant wait to start getting rid of that dang auto just money is always in the way and going to college doesnt help much either. I hope i can do it when i am up in steamboat springs when going to school thats one project to do at least. :driving:
A buddy and I did the swap last week in 5 hours.  You will probobly not get your swap done as fast as that just because you have not been into the dash assembly before.  To swap the pedals you will need to drop the steering column down but its not hard at all when you get the time & $$ to do the swap just ask and I can basically walk you through it step by step.
superstarai
 Well i will probally have my friend/master mechanic help me out here in Dolores Colorado and do it like that hes got a shop
and all the tools 8) Much easier when you have a good hand right there iam not saying i cant do it myself but i just dont have the knowledge or the tools do it or if you prefer i could come over to your place and do it which would probally be more fun with different people and a different place i cant wait to start but then again money hurts. So could i come over some time thanks. :drool: :thumbs: :_oops:
Of course you could come by and do it here.  But the drive would suck, Im in Prosser WA.  Like I said the drive would deffinately suck.
toyotaboy
I didnt need to drop anything... just bolted on the extra pedal for the clutch and changed out the bigger break pedal.. theres a bolt hole for it up there... i did it on the same truck so you have any questions let me know..
And im goign to have to argue.. yes you will need drivshaft work.. you will be runnung dual cases so your going to have to get different lengths..
rest in peace Effay
01 taco needs, duals, front axle, linked rear, exo...
85 extra cab/cab for sale with efi harness. no drivetrain, will sell, make offer
Ok ok I forgot that part.  :smack: yes youll need driveline work. again :smack:
superstarai
 THanks for your help guys :thumbs: I am also wanted to know what type of 85 tranny number it is 5 speed tranny is it a w56? Get back any one have transfer cases or tranny for an 85 with a 5 speed they want to sell? Thanks again. :beerchug:
If it's from an 11/84 to 6/85 22R (Carb) then it's a G52.
If it's from a 7/85 to 12/85 22R (Carb) then it's a G54.
If it's from an 11/84 to 12/85 22RE (EFI) then it's a W56.
G-series Transmission:
W-series Transmission (this is a late model verison [1989+], forward shifting style t/case, without bellhousing):
Regards,
superstarai
 Thanks guys once again i just dont know jack  :slap: Anyways i want to use the w56 5 speed with a dual transfer case set up except with the rear with 5:1 gears in it and a twin stick with the stock t-case in the front hell ya! Or can i get a tranny from 84-87 5speeds and work under my 85x-cab truck with a 22re non turbo also would i have to get a different bellhousing for both trannys? Thanks again for your help. Or i might wait for that t-case marlin is building and put in the rear with stock t-case up front. Thanks again. Anybody want to sell a tranny and t-case i am looking for? thanks. :thumbs: :drool:
Big mike did a write up on the differences n lowrange gears awhile ago.  Im sure he'll have a link to it, worth reading and then not buying AA gears!  Alos in all reality if you find a trans and case from behind a r series engine it will bolt up.  Just find the best deal you can on a trans & case from a 4 cyl, the newer the better as the strength kept increasing with the years.
superstarai
 Okay thanks for your help again. :yupyup:  The 5:1 gears i dont think their aa gears i think their inchworms gears.
Ill see if I can find the writeup, the so called 5:1 gears are not really that low they were something like 4.89's or somewhere around there.  THey had to take a tooth away on the input shaft which is a bad idea since there is a lready a lot of stress in that gear set.  So by weakening it they just made a time bomb.
84runner
superstarai
 Oh know wonder why there the only ones who make it dang i dont want that gearset then! Especially for 650 or 550 either way i dont want to have to replace it with that much money. I'll try marlins 4.7 gearset instead stronger and better anyways thanks again for all the help you guys have given me. :beerchug:
