Auto Hub to Manual Hub Conversion
Started by locknload, June 01, 2004, 09:30:03 AM
locknload
I want to swap my automatic front hubs (On a '87 4runner SR5) for a set of toyota manual hubs I picked up off a parts 4runner. My problem is that the manual hubs don't seem to fit on the hub flange...The hubs don't seat when I snug down the 6 nuts. :smack: Do I need to change other parts in addition to just the hubs?
Ill bet its the lock ring that keeps the wheel beaing nut from coming loose. Sounds like youll need a set of standard hub nuts.
locknload
Thanks WT...So, I guess I'll need to take apart the axle hub/disk brake assembly and replace the adjusting nut, lock washer and lock nut with the manual hub version of these parts?
yup the auto hubs have a different style of nut & keeper correct?  I have the same style as autos on my warn hubs on one of my trucks.  I think that you could use the same setup if you machined off the inner lip of the ring.
Skinny_Pedal
warn also makes a conversion kit that runs for like $75-100. www.4wheelparts.com carries it
Im an OG
yotasrockontherock
my brother just had that done to his 89 runner but his used warn hubs he had to get something called a spindel nut kit for the replacement
85 4runner 5.29s 31x10.50s sr5 2inch shackels
Prismo
Stick with the Aisin hubs. I tried the Warns, let's just say I sold them after I warrantied them both for the second time.
yotasrockontherock
really what happend to them? they have been working good on my brothers rig so far but hes only had them for about a month and you do need a spindle nut conversion kit its $62 in performance
I havent broken my Warns yet either but From what I hear they have a tendancy to loosen up and break the studs that hold them on.  Its not that the hubs are weaker or anything its a design flaw on the warns.  They didnt incorperate the origional cone washer setup in the design of the hub body.  That in/of itself is causing the failures.
Prismo
Quote from: WHITE_TRASH on June 02, 2004, 11:48:10 AM
This happened the first time until I figured that out (Locktite is your friend).  The other 2 I broke during Team Trophy Challenge. Wasted the internals on both. This was when the truck was still IFS. One broke while coming down a waterfall with all of the truck weight on the front & the second broke climbing a large rock & the Lockright racheting under full power in low low (CV failure more than likely caused this one). I have heard the solid axle units have less problems. Warn is awesome as far as customer service goes.
That said, I have NEVER had one problem with the nearly 20 year old Aisin hubs.
