ToyoTanners 1st gen pickemup truck
Started by toyotanner, November 19, 2007, 07:40:45 PM
toyotanner
cool man... i found one on craigslist today w/ an rv cam no intake or exhaust for 250 but the guy was in the process of selling when i called :(
TIMS89CRAWLER
ya it usually works that way with toyota stuff on craigslist around here  :thumbdown:
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
coods
 :beerchug: let me know if you need the picker and we can get that motor pulled
toyotanner
well either way it needs to come out so bring it over tomorrow :D
coods
dam that means i have to unhook the trailer.  :stopit: just to load back up for this weekend
coods
 8) i can drop it off tomo but wont be able to help for that long.  wensday i have nothing planned :blah:
toyotanner
it probably wont take me much more than like 2 hours to get that motor out by myself anyways...
toyotanner
toyotanner
Found some more pics from wheeling at goat about a month ago
toyman80
that last pic looks like browns camp. archer firebreak 5 maybe?
toyotanner
no its all Estacada Goat Mountain
toyotanner
the post that coods left about 5 posts up was mini rubicon on firebreak five though
smokeater87
Quote from: crawlerdan on January 01, 2008, 06:49:47 PM
you can do as many as you got room for, theer is a pic somewhere of marlins shop building 10 cases
not in a truck of course, on the bench. but they did. ask big mike for pics!
So would you just need 3 cases and 2 of the marlin dual adapters???Or is there a different adapter for tripple cases?
Putting the wet stuff on the red stuff!!!!
toyotanner
smokeater87
Wow that would be cool.If i can get the driveline angles right i might just do that.Didnt you have trouble with your angles when you did the flatbelly with dual cases?
toyotanner
yeah i had to put 10 degree shims on the rear axle for the driveline to work
toyotanner
YAY!!!!! i got a motor from a buddy today for 100 bucks its a score for sure. so hopefully this week i will be swapping the new motor in and putting all my stuff on it and putting the L52 and attaching the duals to that.
GrenadedToy
who did you get a motor from?
toyotanner
toyotanner
sooooo.... got some pics for everyone...
this is what was left of my #2 rod bearing
This is the new motor w/ all my stuff on it
This is my new tranny and whats gonna be my rear case
with the room i had with the motor out i decided to gusset my shock towers and plate my frame for 1 of my steering box bolts
toyotanner
oh and i got the motor in and started seems like its gonna be a good runner.
TIMS89CRAWLER
good so you better be up at browns wheelin with us on march 6-8 we got a grip of rigs coming up to tear some :pokinit: up! :yupyup:
www.choptechfab.com
CHECK THE BUILD
toyotanner
yeah more than likely i will be down to go... march is pretty early though might be to much snow still
TIMS89CRAWLER
ya guess we will see... there is quite a few rigs going from down this way though so it should be a good time! hope you can make it and drag some buddies with ya too!
www.choptechfab.com
CHECK THE BUILD
toyotanner
Driveline welds
New driveline alot thicker material too
new motor in its new home
toyotanner
checklist before i can wheel it again :) :
* clearance xmember for front driveline
* fix motor oil leak ( i think its the front main)
* gear oil in trans and cases
* buy and install 2 knuckle studs
Things i want to try to do soon...
* bob and dovetail the bed have some ideas on ways to do it
* get my trans tunnel and floor piece bent up and welded in
parts i have that i should probably install sometime...
*knuckle ball gussets
*skyjacker extended front brake lines
*upper axle gusset
OH man and my tags are up this month so i have to put a cat on it and take it through DEQ :(
TIMS89CRAWLER
get it done... ya got till march 6th
www.choptechfab.com
CHECK THE BUILD
