Author Topic: lug nut trouble  (Read 7568 times)
12GA.YOTA
  • Male Posts: 143
  • Member since Aug '07
lug nut trouble
« on: Nov 17, 2007, 09:53:59 PM »
p/o put some of those special lug nuts that takes a specific key to take off but I don't have the key, they are on all of the lugs 24 of them dose any body know an easy way of getting these off, I heard you can hammer a socket to them but I don't want to loose 24 sockets. these lug nuts are round with grooves cut into them in different places so only that key can grab it. any thing could help thanks
84 toy 5" suspension, 2" shackle, new 35" Boggers, Detroit rear, tru-trac front, 5.29 gears, custom made bumpers f/r, custom sliders, racing seats with 4 point harness, marlin 4.70:1 t-case,stock 4 banger with sincro Webber carb
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: lug nut trouble
« Reply #1 on: Nov 17, 2007, 10:39:53 PM »
Take it to a tire shop.
skipnrocks
  • Turtle Points: 212
  • Male Posts: 2,363
  • Member since Mar '06
  • DUDE YOU DID WHAT?
Re: lug nut trouble
« Reply #2 on: Nov 18, 2007, 12:43:04 AM »
Do you remember where you bought the lugnuts from, I understand that each company would have a standard key, with the exception of maybe some of the upperend companies that maybe have something more special...
Could you fab a key?
WILLYNILLY
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
Re: lug nut trouble
« Reply #3 on: Nov 18, 2007, 09:20:16 AM »
grind off the chrome then weld a nut to the lug, bust the nut off and put a band-aid on those bleeding knuckles. next get a chisal and try to beat them in the off direction.
more band-aids please.
then take a cutting torch to them, cut the lugs off the bolts, after you've been relisted from the burn unit take it to the tire store. :twocents:
Stocker
  • Turtle Points: 962
  • Male Posts: 173
  • Member since Oct '05
  • Since 1977
Re: lug nut trouble
« Reply #4 on: Nov 18, 2007, 10:25:26 AM »
I had a set of those years ago, and they were pretty soft...  Vice-grips might work.  Of course the locks will get all boogered up, but you'll probably be tossing them anyway.
My goal in life is to be as a good a person as my dog already thinks I am.
If you don't learn something every day, you're not paying attention.
germ
  • Turtle Points: 349
  • Male Posts: 733
  • Member since Dec '04
  • Work sucks, I'm goin' wheelin
Re: lug nut trouble
« Reply #5 on: Nov 18, 2007, 10:32:04 AM »
Tire shops usually have a "Nut" remover. Typically charge a few more pennies for their trouble, but occasionally worth the $$ to avoid the @#$%^&^%$$%^*& of busting your knuckles. I had a similar problem few years ago, and they were able to get them off without much difficulty, and cost me like 4 or 5$
Erik
skipnrocks
  • Male Posts: 2,363
Re: lug nut trouble
« Reply #6 on: Nov 18, 2007, 11:42:16 AM »
Erik
Thats what I would try, 5 bucks would be well worth your time,  you could just call around too and find out who will help you out, some shops may just let you borrow the tool in front of their shop...
WILLYNILLY
DanS
  • Turtle Points: 5
  • Male Posts: 434
  • Member since May '06
Re: lug nut trouble
« Reply #7 on: Nov 18, 2007, 11:53:57 AM »
X2, tire shops are well versed with owners who lose these locks, good luck.
DanS
Wow, been looking at my 4Runner rust away too long, need some inspiration and here I will find it...!
85 Toyota 4Runner, solid axle, 22Re, original paint and graphics and not a straight panel to be found!
12GA.YOTA [OP]
  • Male Posts: 143
Re: lug nut trouble
« Reply #8 on: Nov 18, 2007, 12:48:45 PM »
Thanks for the advice. I have a freind that works at the junk yard and every time he finds alug nut key he snags it so he luckily had one that fit, guess they arent one of a kind afterall
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: lug nut trouble
« Reply #9 on: Nov 18, 2007, 08:53:18 PM »
There is a socket that will remove them, tires stores carry them but it may be cheaper to buy a set in your case. When I bought my truck it had locks on them and the kid I bought it from couldn't find the key-lock so my next door nieghbor had a set and we had all 4 off in about 10 min.
dt
  • Turtle Points: -107
  • Member since Oct '07
Re: lug nut trouble
« Reply #10 on: Nov 23, 2007, 12:37:33 AM »
I welded on some and that softened the metal and then I could get a grip on them with vicegrips
  • Administrator
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: lug nut trouble
« Reply #11 on: Nov 23, 2007, 01:15:19 AM »
Welding will make a steel harder and more brittle assuming its temperature has risen above the eutectic range. If so, then its microstructure will turn into austenite, and depending on how you cool them down, your likely to get some martensite forming along with some bainite, which is extremely brittle due to the fact that most of its remaining carbon will transform without diffusion, so you will have carbon atom interstitials which prevent slip dislocations to form and thereby creating an instant fracture which is brittle by nature.
If you wanted to weld on them only to play with the microstructure, then I would recommend getting them very hot (above 700 degrees C) and then immediately quenching them with a continueous stream of water. This will increase the weight percent of martensite and will give you the most brittle result to play with (shatter it baby!)
Of course this will make your studs brittle as well, so therefore don't weld on lug nuts!! Sheeesh
Ideally you would want to try to get Pearlite (a very strong microstructure) to form, or even better some Spherodite, but you will need to cool it very slowly by holding them in an oven of some sort, which wouldn't work here...
Yup, just take it to a tire shop :thumbs:
  • Administrator
  • 511:1 Club
Re: lug nut trouble
« Reply #12 on: Nov 23, 2007, 01:31:13 AM »
Ah, now if you weld and heat them up to its invariant point, or some other point near its liquidus line where you have a liquid-solid solution, and then grip it with some vicegrips immediately before quenching it below 200 C to form your martensite, then you would be able to deform the nuts enough for the vicegrips to lock onto them and then extract them.
Of course you would have to take into account the fact that the vicegrips themselves will loose their heat treatment and they will become fused together with the nut you will need to grind off...
This approach seems possible, but the liquidus line should be in excess of 1,100 C and I don't know if many welders can achieve this or not, plus you have to keep it above that point while you are welding it and moving the vice grip around. :flamer:
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
Re: lug nut trouble
« Reply #13 on: Nov 23, 2007, 10:00:36 AM »
 :ha_ha: :ha_ha:
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
Re: lug nut trouble
« Reply #14 on: Nov 24, 2007, 12:40:22 PM »
Awwwww, what ???
Doof
  • Turtle Points: 41
  • Male Posts: 3,205
  • Member since Apr '07
  • establised summer of 89
Re: lug nut trouble
« Reply #15 on: Nov 24, 2007, 09:54:50 PM »
i only followd all that because of my fire class which is basically a chem class, but even so that was very confusing and how could you think of stuff that technical at 130am?
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
  • out from under my rock, and ready to roll
Re: lug nut trouble
« Reply #16 on: Nov 25, 2007, 08:14:53 AM »
Nice info Mike. Someone was paying attention in class.  :thumbs:
I have run into a simular problem before nd lucily for me it was on a car with nonexistance backspacing on the wheels. I was able to grind some flat spots onto the lugnuts, and use a wrench to get the lugs broke loose.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
Re: lug nut trouble
« Reply #17 on: Nov 29, 2007, 10:49:56 AM »
I ran into this one time on my truck..   GO to Homedepo and buy a concrete chisel with hex shaft on it for about $10 then go home and with your grinder cut notch the same size as the chisel then but a socket the same size as the hex on the back and start turing... all done.
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: lug nut trouble
« Reply #18 on: Nov 29, 2007, 10:54:44 AM »
I just find a 12pt socket that is just smaller than the lug, hit the hell out of it to fit it on the lug, then remove. :hammerhead:
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • AKA Baja Brad
Re: lug nut trouble
« Reply #19 on: Dec 03, 2007, 08:53:20 PM »
Gator Grip, never tried it but it could work.
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Re: lug nut trouble
« Reply #20 on: Dec 03, 2007, 09:46:45 PM »
Those things suck.  They only work on stuff that is a little tighter than finger tight, if that, and they don't work on anything deep.  My mom has one, and it is completely worthless  :thumbdown:
              -Ronald Reagan
skyscraper
  • Male Posts: 589
  • Member since Jan '07
Re: lug nut trouble
« Reply #21 on: Dec 03, 2007, 10:06:11 PM »
I work at tire pros, and we have a set of bolt extractors just for this problem.  Just hammer it on snug, then hit it with a breakrer bar or impact.  12pt socket will do the same if your willing to sacrifice it, but you would have to really hit it on there good before trying to turn, otherwise it'll slip.  A big set of vise grips sometimes will work too.  I would never weld on it because of the heat damage.  I think big mike took care of that though...
skipnrocks
  • Male Posts: 2,363
Re: lug nut trouble
« Reply #22 on: Dec 04, 2007, 06:54:52 AM »
I have the gator grip brand and it worked awesome for tearing my truck apart and did fine on the things that were pretty stuck too the only problem I had with it was contamination made some of the prongs get stuck in and then it stoped working on hard stuff.
WILLYNILLY
Redeyejedi
  • Male Posts: 115
Re: lug nut trouble
« Reply #23 on: Dec 04, 2007, 04:07:23 PM »
x13 on da tire shop!!! they may be able to locate a key for you. those gator grips suckballs. wont do didly on lugs, barely do squat on nuts. i remeber metwrench from sears/craftsman(i think) was better for stripped bolts/nuts, but for dem luglox, i'd try to hunt down a proper key if possible, may save some headache. just my too scents.
alcohol.....the cause of, and solution to, all life's problems
http://www.flickr.com/photos/78234902@N06/
Doof
  • Turtle Points: 41
  • Male Posts: 3,205
Re: lug nut trouble
« Reply #24 on: Dec 04, 2007, 04:38:15 PM »
take a pic of the pattern...i might have a key you can buy if you want
12GA.YOTA [OP]
  • Male Posts: 143
Re: lug nut trouble
« Reply #25 on: Dec 04, 2007, 06:53:42 PM »
I got them off and threw them out and got a new set of 4, one on each wheele should do fine to protect my brand new 35" boggers and rock crawler black steely rims, thanx for all the help and advice  :bowdown:  :thumbs:
skipnrocks
  • Male Posts: 2,363
Re: lug nut trouble
« Reply #26 on: Dec 04, 2007, 07:51:17 PM »
What after all this your not going to tell us how you got them off??? :moon:
WILLYNILLY
Stocker
  • Male Posts: 173
  • Since 1977
Re: lug nut trouble
« Reply #27 on: Dec 04, 2007, 08:21:19 PM »
^^ + 1  :moon:   :gap:
skyscraper
  • Male Posts: 589
Re: lug nut trouble
« Reply #28 on: Dec 05, 2007, 01:20:12 PM »
x3
12GA.YOTA [OP]
  • Male Posts: 143
Re: lug nut trouble
« Reply #29 on: Dec 05, 2007, 04:22:23 PM »
Last post May 15, 2012, 09:16:47 PM
by Steve_925
Last post Aug 21, 2012, 04:21:42 PM
by BigMike
Last post Nov 22, 2015, 09:41:06 PM
by crazymoritz97
Last post Oct 02, 2017, 04:32:04 PM
by toyodaaddict
Last post Jun 09, 2018, 11:53:55 PM
by drayday55
