Author Topic: aisin hub locker  (Read 2234 times)
bad luck
  • Turtle Points: 897
  • Male Posts: 271
  • Member since Sep '07
  • sas!
aisin hub locker
« on: Nov 16, 2007, 11:24:41 PM »
having problem getting them off my axle so that i can put vented rotors on it's my first runner  :help:   :hammer:
« Last Edit: Nov 16, 2007, 11:32:14 PM by bad luck »
highridin4x4
  • Male Posts: 237
Re: aisin hub locker
« Reply #1 on: Nov 17, 2007, 05:46:44 AM »
Are you talking about the cone washers behind the nut that hold the lock/unlock hub on? If so they are a pain because as the nut get tight it pushes the taper together more. If you tap on the stud with a soft hammer it may loosen the washers up (I would leave the nut loose on the stud in case to mess the threads up you can use the nut to clean them back up). Or you might try putting two nuts on the studs and tighten the nuts together and use them to remove the studs from the hub mount.
Hope this helped
Scott
  • Shoutbox Moderator
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #2 on: Nov 17, 2007, 01:05:28 PM »
a soft hammer
i use a small brass drift...soak them in penetrating blaster first
Hyena
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #3 on: Nov 17, 2007, 01:34:49 PM »
hit the hub body side to side, not too hard but not too soft.  the side to side motion should loosen them up.  don't hit the studs but the body they go into.
  • Male Posts: 7,110
« Reply #4 on: Nov 17, 2007, 01:35:34 PM »
oh ya i usually hit it really hard with a rubber mallet (the body)  :biggthumpup:
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #5 on: Nov 17, 2007, 01:42:40 PM »
Yes the rubber mallet is best, smack the black part of the hub side to side top and bottom and it will slowly work the cones out.
bad luck [OP]
  • Male Posts: 271
  • sas!
« Reply #6 on: Nov 17, 2007, 02:10:45 PM »
thanks thats what i was thinking. but wanted to see what you guys would sugest  :disturbed:
lucky7
  • Turtle Points: 303
  • Male Posts: 778
  • CAN'T POLISH A TURD!
« Reply #7 on: Nov 17, 2007, 04:49:16 PM »
rubber malet side to side :_order:
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #8 on: Nov 17, 2007, 10:51:46 PM »
I put a little bit of anti-sleeze on the conical washers when I re-install them
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #9 on: Nov 18, 2007, 03:24:35 PM »
I just use a chisel I filed down to fit in the crack. A few whacks on that, and the cone comes right out. Don't use screwdrivers though! They break and leave metal chunks in the slit of the cone washer. I will probably try the hit the body with a hammer method next time to see if it is easier.
DeadlyPeace
  • Male Posts: 593
  • Member since Nov '07
  • HEAVILY medicated for your protection!
    • ToyotaOffRoad
« Reply #10 on: Nov 19, 2007, 09:30:31 AM »
I've alway loosing the cone washers by tapping the body with a hammer and then any that didn't want to slide right off I would use a screwdriver in the slot from the side of the cone washer. Tap it in with my hand and slide it off.
Never let people think you’re a horrible person and always keep the heart of a young child…
« Reply #11 on: Nov 19, 2007, 09:37:28 AM »
leave the nut on  the end of the stud   so when you smack the hub body  the cone washer doesnt hit you in the :eye:  or get lost
DeadlyPeace
  • Male Posts: 593
    • ToyotaOffRoad
« Reply #12 on: Nov 19, 2007, 10:09:27 AM »
Haven't ever had that problem yet, but probably some good advice just in case. :greengrin:
84pickup
  • Male Posts: 335
  • Barnwell Mountain (stock) Texas TrailRiders Jam 08
« Reply #13 on: Nov 19, 2007, 12:54:49 PM »
i haven't had any problems with hitting on the studs but i also hit side to side on the body.
lets not and say we did.
  • Male Posts: 7,110
« Reply #14 on: Nov 19, 2007, 01:11:54 PM »
ya i forgot to say that x2
this is very im portant!
DeadlyPeace
  • Male Posts: 593
    • ToyotaOffRoad
« Reply #15 on: Nov 20, 2007, 10:14:20 AM »
Haven't done this for the hubs, but probably not a bad time to start. Although I do do this to the cone washer on my Hi-steer arms.
Last post Apr 25, 2005, 02:26:44 PM
by ksmith
Last post Mar 10, 2006, 04:04:17 PM
by toy4crawlin
Last post Feb 25, 2006, 08:27:15 PM
by nowhitefenders
Last post Dec 10, 2006, 12:58:26 PM
by Marc P
Last post Dec 11, 2006, 11:13:25 AM
by Homeless Dog
