IFS steering box rebuild
Started by ezthere, May 27, 2004, 05:39:32 PM
ezthere
OK I want to rebuild an IFS steering box. Then I will buy Marlins High Steer, I will also buy the 4.7.1 transfer case gearing... But first I need to find a place that sells the rebuild kit. Does any one out there know of a rebuild kit for the Toyota IFS steering box. :dunno:   .Please post a link.
Thanks again Chuck
Chuck
Marlin
I am only aware of the factory kit.
Be aware, you are talking about opening up a can of worms. Unless you have done this a couple of times before and you have some trick thin wall sockets, i would advise against it.
I have rebuilt two boxes, and had to buy two more good boxes from the wrecking yard to make the job right.
ezthere
Ok thanks. Marlin. I don't need any worms.
Chuck
