Fully built 1987 Toyota 4Runner for sale.
Started by Geno, November 14, 2007, 06:39:57 PM
Geno
SOLD SOLD SOLD   :rivers:
Motivated seller, make reasonable offers.
I bought this from a pirate member a couple years ago and it has been a great rig.  Life priorities have changed and my toys need to go.  It has been sitting for a few months but still starts right up.  I just changed all the fluids in it and need to clean the inside a bit but other than that it is ready to go.
VEHICLE
1987 4Runner SR5, about 9,000 miles on new drive train. Clean title in my possession, currently green stickered.
MOTOR
Toyota 22RE with fresh rebuild using factory new Toyota turbo pistons, bored .030, 8.0:1 compression, Calico coated bearings, adjustable timing chain with steel guides, new turbo head, new factory turbo valves, bronze valve guides. EGR is removed but included. Brand-new Optima redtop battery and under hood ARB compressor with fresh solenoids to power lockers.
TRANSMISSION
23-spline R151F Turbo transmission, five-speed, 4.31 first gear.
TRANSFER CASES (DUAL)
Marlin dual 23-spline transfer cases. Front case is 23-spline stock 2.28:1 gears, rear is 4.7:1 Marlin gears. Marlin adapter. Budbuilt crossmember. Overall crawl in low-low-first is 245:1.
FRONT AXLE
85 solid front axle, ARB air locker, 5.29 gears, new Longfield 30-spline chromo inners and outers and fresh complete rebuild kit (felts, seals, bronze bushings, etc.). Has 1.5-inch wheel spacers. Vented font discs. Rancho 9012 shocks on Ford shock towers.  ARP Hub and Knuckle studs.  Trail-Gear Rock-Ring Knuckle felt protectors and Backing plate eliminator.  Marlin heavy duty front inner axles seals.
REAR AXLE
Rear axle is 1987 wide rear housing with V6 third member, 5.29s, ARB air locker (freshly rebuilt with all-new seals). TSM rear disc brakes and trick hydraulic e-brake setup. RS 9000 shocks /\.
STEERING
IFS box securely frame mounted plumbed for hydraulic assist. Sweet Bros. 8-inch ram on custom mount. New Chromoly All Pro high-steer arms and linkage
BODY
Typical trail rig with some Bondo and dents. Driver side windshield is cracked, you can see it in pic. Bed bobbed 13 inches with custom soft top. Painted Aervoe mil-spec OD green. Has quick-release full working doors (with AOR inserts) as well as AOR tube doors. Also has hood scoop and cool weight-saving aluminum tailgate.
SUSPENSION
All-Pro 5-inch springs all around.
WHEELS/TIRES
37x12.50-15 MTR's, about 90 percent on 15x10 2.5bs wheels.
PROTECTION/WINCH
Custom tube bumpers (built by HeyBeerMan) front and rear with receiver in rear and stinger up front. New 9k Warn Tabor winch with one pull in custom mount inset into grill. Square tube sliders.
INTERIOR
OK shape, a little dirty, but no major damage. SR5 seats are a little dirty but complete and comfortable. All gauges work (except fuel cage which is disconnected), including clineometer, Smittybuilt bolt-in cage, 15 gallon RCI aluminum fuel cell behind pass. seat, in-dash Alpine CD player with two front speakers with amp and sub. Alpine Ipod connector installed. No rear seat.
SPARES
One 27-spline ringed Longfield joint with both long and short inner as trail spares, bed mat and all associated small parts plus a Haynes manual.
PRICE/TRADES
$8,000 OBO. This rig is extremely well-built and complete with exceptional attention to detail. It's completely turn-key, get in and go wheel. Located in Chico, CA. 530-354-5292 - Rick
OFRD_GRL – as much as i appreciate strip clubs, i could never date a chic. they are all flopin crazy.
Geno
fatt_matt
Jeep
Geno
zukjunkie13
If i wasnt a broke college student :rivers:
i would buy this in a heart beat .
I really like it.  :willynilly:
Life's journy is NOT about arriving at the grave peacefully in a well-preserved body, but rather to skid in sideways, worn out and beaten, shoutin HOLY Sh** what a ride!!!
crawlinforcrohns.org
bigarms23
does it come with a hard top? also is it streetable
kiyul4130
this is a very clean rig and can deffinetally go probably anywhere you pointed it. ive wheeled with rick many times rock/snow and the rigs in a great condition. it is streetable.  oh and rick dont sell it!!!!!!!!!!!! make it through one more snow season.  :down:
-kiyul-
ECV 7-11
KYOTA FOREVER
Geno
It does not have a hard top.  It is currently green stickered.  You would have to put the smog equipment back on it and get it smogged if you wanted to drive it on the street.
AaronB
Geno
Geno
Geno
If I am asking too much, let me know. I am willing to negotiate on price and I can deliver within 200 miles.
I have a new car trailer for sale as well, I have used it 4 times.  $1700 OBO.  I will post it up later today.
Geno
Need to sell 4Runner first before I can sell trailer.
Here is the link to the trailer.
http://www.performancespecialty.com/ProductDetails.aspx?productID=28
Comes with spare tire and Recessed "D" Ring Tie Downs.
8 1/2' (82") wide California Car Haulers have the following features:
7,000 lb. GVWR
Open center to save weight
Steel Runers (All steel trailer, no wood)
Wrap around tongue for added strength
Electric Brakes on one axle
15" Custom Wheels
New 6pr trailer specific tires
DOT approved light package
2 5/16" Ball hitch
2,000 lb. Tongue jack
Ramps and Ramp storage
82" between the fenders.
Geno
wow, yeah they did... it reminds me of the celica hoods on like the early 90s.
i want a hood like that.
EarlKann
 :phone:  Got off the phone with Rick.  Gonna go and get it on Friday!   :banana: :spin: :woohoo:
EarlKann
bitchin... can i have your hood when before you hack it up? :D
EarlKann
Quote from: ImahoToy85 on November 20, 2007, 09:19:29 AM
Have?...perhaps a simple trade.  :beer:
Where are you located?  Shipping is a pregnant dog on a hood!
yeah true. i have half doors, my trimmed fenders that are straight, i will have a stock 3rd from 87 i sold.. baconator hasnt taken out what i wanted to keep. and i have 22re block and head.
iNfErNaL
Whatup Rick?.You building something else?.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
EarlKann
Quote from: Infernal on November 20, 2007, 09:43:09 AM
He said that he was going to buy a house.
lilbuddy
RIP Kyota.... you are the man
GET IT!!!
kiyul4130
-kiyul-
ECV 7-11
KYOTA FOREVER
EarlKann
Don't be sad.  It'll get to see the Hammers once before it becomes a Formula Toy.  I'll get pics.
