4.88 gear?
Started by konatoy, May 25, 2004, 02:56:56 AM
konatoy
this might be a dumb question, but i need to learn. I got a 79 pickup, and 33s on it, and will 4.88 gears, make me crawl slower, or higher highway speeds, or what??? If not, whats the easist way to crawl a little slower?. One more thing, is the All Pro off road Extreame lifts, any good???
kyle_22r
they'll pick up the slack for those 33s.  theoretically it'll lower your top speed but our engines aren't really powerful enough to worry about that.  with my stock 4.38s my top speed is about 65 on flat ground with 31s.  then again my engine is 1/3 the way to a million miles without a rebuild
for most trucks 4.88s and 33s will get your speedo back on track too, with a '79-80 pickup like ours if you want to do that you'd either need to swap in a speedo gear from an '82-up truck('81 had 3.90s in them) or go to 5.29s if you want to get your speedometer closer to stock
brainlessfool
I've got 4:88s with 33s in my 83. it runs alittle high, RPM wise on the freeway.  speedo is off by about 6 mph @ 65. shows 70@65. and it did slow my crawl down abit. but mostly helped with starting out in frist gear. I think 4:56 will get you back to "stock".
mr4x42u
Quote from: young-boy-old-toy79 on May 25, 2004, 02:56:56 AM
Basicly the higher number is a lower gear and will be better from crawling..  Thats why so many run the duel case to double the reduction in 4low..  so you go from a stock 37.1 crawl ratio  then change gears,say 4.88 in your case and now your at 44.1..well now you add t-case gears OR a duel case and your at about a 100.1..higher gear for top end,,,4.10, 3.90 and so on..
Tire size also effects crawl ratio..so when I say thats your stock ratio thats with stock tires..As the tire size gets bigger your ACTUAL ratio drops..Thats whay with 4.88 and 33 tires your right back wher you started.So duel case your rig or get some transfercase gears..Hope that helps some :biggthumpup:
mr4x42u
Oh yea if you want more gear ratio info go to marlins home page and click on top by tech info..ToNS or info that its mind boggling but helpful and good to know.
84runner
A friend of mine is running All Pro's Extreme lift and It is nice. I think it is  one of the nicest kits that you can get off the shelf without haveing to special order custom springs. I am only refering to the springs though, I don't know about the hysteer, and the other components. But the springs are very nice for a off the shelf spring kit. But they can be out done by customs springs
yotaboy79
if i could aford it i would definetly go with the allpro lift, it comes with pritty much every thing you need do do it but its quite abit of money to fork out on just i lift kit
konatoy
thanks a bunch guys, I kind of just wanted to get All pros springs, and long travel shock loops. But All Pro said you need the hy-steer kit too. And for 79s you need to buy a whole new box, so its a lot of $$
yotaboy79
yeah eather way you look at it your gunna be forking out some cash, unless you build custom spring packs and do hillbilly hi steer
konatoy
hill billy hi steer??? how does that work, and how could i get that??? Also what about that idea of switching the stock springs(rear) up to the front, and get chevys back rear? How well does that work? and what model, year, chevys??? thanks
I could answer all your questions but it would take awhile, the easiest answer is to look at both my $300 thread from the begining and Kyotas 83 buildup.  Between both threads there are more answers then you have asked so far.
yotaboy79
yeah i swear that white trash is the invintor of hill billy high steer
kyle_22r
i might just go cheap and stick with push pull steering for now and find a different box(mine pisses fluid).  i don't think my truck is gonna need any insane flex for what i do for the most part.  i'm just scared of breaking a j arm  :nerv:
yotaboy79
then carry a spare  :thumbs:
