auto trans and marlin t-case??
Started by axle, May 24, 2004, 05:38:39 PM
axle
I just signed up and mentioned this in the newbie section but I thought I'd get more attention here. I have an 86 pick-up  with a 22re and auto trans(not sure what the model # is for it). but I need to find out what I've got to do to get dual t-cases and keep the auto trans. Is this even possible? Any help would be appreciated.
thanks
Roktoys84
I have the same dilema. I've been told that you can't bolt a Marlin Crawler to the A340.
QuoteOriginally posted by Marlin
To install a dual case, you need a auto trans that has a unboltable t-case. It always will have a manual shift handle and is found on 93-98 T100's and 96-newer Tacoma, 4 runners. If your trans uses 9 bolts to attach the transfercase to the back of the trans, then a Marlin would bolt right on using my 1/2" adapter plate to a 23 spline gear driven t-case.
For some info on swapping your auto for a 5 speed check out this thread.
Good luck and keep us posted. :biggthumpup:
Size doesn't matter... yet.
A good friend will bail you out, but your best friend will be sitting next to you saying "that was f---ing awesome."
Marketing
We do not have plans to support the older auto trannys at this time.
