Auto to 5-speed swap/88 4Runner 22RE/SAS build-up
Started by Rollover Roy, February 22, 2004, 10:51:21 AM
Rollover Roy
I am in the middle of building a runner that originally had an auto trans. As I run across things I will post them here. Any input would appreciated.
We'll start with the computers. Marlin said I should be able to swap this 88 AT for this 85 MT. I give it a try and post what I find.
- Roy
Here's the 88 AT......
There is no good excuse not to follow the pick-up!
Rollover Roy
Rollover Roy
I also found that the brake pedal bracket was the same as a manual trans braket and it was easy to swap the pedals out of my 83 right into the 88. Drilled out for the clutch master and ran the line to the slave.
84runner
Marlin
The starter solenoid wire will need to be jumped because the netural safety switch on the side of the auto transmission is going away with the old trans.
I jump the white? wires on the factory plug above the starter.
MC
Rollover Roy
#5
Dropped the newly rebuilt motor in Sat. and put my 1996 crawler in between my new W56HD and 4.7 to 1 t-case that I picked up from Marlin at TDS.
Tranny in and motor started next weekend!    :crossed:
It's hard to keep my mind on this boreing stuff and not think ahead to the SAS and cage projects.
- Roy
Rollover Roy
My neighbors love me.
brainlessfool
Marlin
You will need to connect the two larger wires on the auto loom above the starter. It is the white and black wires.
Hope you received the 4 shift handle bolts.
Your old L52 had a wasted front bearing-still a good core
Thanks Marlin
Rollover Roy
Quote from: Marlin on March 15, 2004, 10:44:09 PM
Thanks Marlin
Thanks for the help Marlin. Got the bolts the following Tuesday.  I'm glad the bearing dropped onto the floor at your shop instead of halfway up Jackhammer. I'm glad I didn't go the cheapskate route and try to make the L52 work. If all the people I deal with in this game were as kind and professional as you have been, I'd be out of money.
Thanks again,
- Roy
johnyreb69
could you send me a step by step i want to swap outr my suto tranny for a manual as well its a 86 runner EFI 4cyl non-turbo
-- Fear is our only enemy
    Stand tall in the face of your enemies
    And you will conquer --
Bernabe Frank Rodriguez, EIT (Thats Me!)
luigi
Quote from: Rollover Roy on February 22, 2004, 10:51:21 AM
- Roy
Why change computers, I did the swap and didn't change them, smogged just fine.  Am I missing something. :dunno:
85 4 Runner
22RE Auto to 5speed swap
Marlin Crawler Dual Ultimate Case
5.29s
Arb's front and rear
Rapidly denting away my "Mall Runner Status"
Rollover Roy
Quote from: luigi on April 11, 2004, 03:00:43 PM
- Roy
Marlin said somthing about performance. The auto trans comp. needs some kind of input from the trans to work at peak hp. smog isn't the issue. I've heard the same from other sources. I haven't run the truck yet but will have it running by this weekend. I plan on swaping back and fourth with the auto comp. and the manual comp. to see the difference. I will post my findings.
- Roy
cgbemis
Hey roy,
     Glad to see your project underway. Just got in a turbo charger and fuel injection for your old motor :eyebrow:. Still got an axle for me? I know I lag.
Rollover Roy
Quote from: cgbemis on April 15, 2004, 09:08:19 PM
Hey roy,
Hey Cullen. Thanks. Its running and will be on the road long enough to breaking the motor and then it goes back on stands to lose the IFS. Yes I still have the axle. Let me know when your ready for it or I'll let you know when it gets in my way.
- Roy
Rollover Roy
I know I haven't updated in a while but the Runner is making slow bt sure progress and the project is picking up speed as the season draws near. The wife just had a little boy so I'll need the four seater to fit the new four member family. I'm not good at build-up pictorials so here's a few pictures and coments. Post up with questions or coments.
- Roy
The auto trans is history as is the IFS.
Rollover Roy
Started the SAS this weekend (10-2) and rebuilt the front and rear axles compleatly. Note the new bling rims.
Rollover Roy
#17
More pics and storys to come as time permits. (see pic below!) This rig will be rolling by christmas and should be tested and completed with armor by TDS. Thanks to Marlin for the W56HD and 4.70 T-case. That 223 to 1 final ratio will come in handy with the 37's.
- Roy
This is the wonderful reason you haven't heard from me in a while......
Alex Roy Dew 9 lbs 9 oz. 9-17-04
brainlessfool
Congrats on the new wheeler in the family  :beerchug:
have a point for the kids!
Rollover Roy
More pictures.
I hate grinding......
- Roy
cgbemis
Hey Roy,
     glad to see it all coming together. Which birfs and suspension did you end up going with? Also, congrats on the son. :greengrin:
Rollover Roy
Quote from: cgbemis on October 19, 2004, 10:45:23 PM
Hey Roy,
All pro sas and long's with cromo inners.
Here's a couple more shots......
- Roy
KYOTA
Hey Roy, havent followed the build lately but Damn!! that thing turned out real nice!! Makes me wanna go buy some 37's. Congrats on the new guy and the gauges work awesome :thumbs:  :beerchug:
Skinny_Pedal
dam that is a cool runner. hope my sas comes out like that but on a smaller scale
Im an OG
Rollover Roy
It rolls and steers. Shocks next.
- ROR
reklund5
Those wheels look GREAT!!!  Are they Walker Evans???
I've done 2 SAS's on 4Runners, and they both look like the rear end sags about 1.5"...does yours sit level?  It's hard to tell in the pics
Good Work!
Ryan
Mike D
that looks sweet with the 37's  :thumbs:
Also the reasons people think runners sag so much is cause the front fenders are naturally higher than the rear fenders
Rollover Roy
Quote from: reklund5 on November 03, 2004, 08:24:51 PM
Good Work!
Ryan
Yes! The rims are 17" Walkers. It looks like somone put hubcaps on a tractor huh? Yes rear droops a little. However I haven't worked the front springs at all yet and I'm planning on a heavy duty bumper and winch. Should settle just right. It's a little to high right now.
- Roy
iNfErNaL
Day-um!!...That Runner is coming along really nice!...Is that Off Road General Store?.Anyway,keep up the good work,it looks really good so far...And congrats on your new son...I got one coming December 28th,and I also have a 3 year old son...It really makes me feel good when I see fellow wheelers that have kids,and are still hardcore in the sport...My goal to have my junk done by is TDS as well....See you there. :thumbs:.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
