Im getting a tapping noise in my brand new rebuilt motor ... Its not loud at all, and doesnt sound like anything serious, but its bugging my to death. Its only noticable when you rev then motor up and listen as it revs back down. Its a fast paced tap... taptaptaptap. Ive checked the valve adjustment many times and its good. I took all belts off and ran for a second and could still here it, so you can count out the water pump and power steering pullys. I guess it could maybe be an exhast leak? I know for a fact my tranny is making noises but this to me sounds like the front of the motor, but i could be wrong. The tranny makes noises when i let off the gas and leave the clutch out at higher speeds. A 5 speed will be replacing that soon though. any body have any ideas? I know its hard to tell since you all cant hear it. But at least i tried.
i rebuilt the motor myself, installed brand new chain, tensioner, sprockets and guides. almost positive i didnt use the wrong bolts in the cover or oil pump or water pump, but ill check the guides for wear... The valve cover may do the trick, i do have it pretty tight becuase i kept getting a small leak. Ill also tighten the exhast valves a little bit to .010. Thanks alot for the tips. hopefully this will fix it! She runs to good for anything to serious to be wrong i think. we will see.
No exhast leak. Got a stethascope and im pretty sure its comming from the bottom end. Pisses me off. i dont know what to do now. I need to take it to someone with knowledge of 22r/s and let them listen i guess.
Started by 91Toyota4x4 Engine
Started by bulldaddyb Toyota Pickup/4Runner Tech 1979-95
Started by Mega Baby Huey Toyota Pickup/4Runner Tech 1979-95
Started by xcuzzi New Member Check-In!
Started by Wainiha Engine
