electronic speedometer troubles 94 pickup
Started by 79coyotefrg, October 27, 2007, 01:43:57 PM
yep,   one of my local guys triophan  on TTORA ,  his 94 truck  speedo  quit,  i was going to give him a cable  but  realised  he has the electric speedo sensor.    what does he need to check??   did the  sensor go out??  :dunno:  fuse ??
93tonkatoy
Check the wiring connection to the sensor to make sure it is clean. if no change, the sensor is fubar. Replacement, last i checked here, was $214. May get lucky in a junkyard. Or, get an older cable type gear and get Marlin's adapter. That would probably be cheaper.
SAVE TELLICO post 491
