The sickest TOY build EVER on 40's *snow pics*
Started by ToYocRawleR, October 15, 2007, 01:45:28 PM
Thomas P
did you fix your fuel problem? if so it will take a while to get fuel flowing again, when i started my new motor last weekend, i had to turn it over for at least 1 minute before it got fuel
'14 Camry SE
SCX10 Honcho on roids!
MiniSimp
to get the fuel back in the system use the fuel pump test jumper then just loosen the cold start injector bolt until fuel sprays out, retighten it,  then start it.
ToYocRawleR
Its hella weird.  It will start with starting fluid and sometimes on its own but its rough at first then idles perfect.  Timing is dead on. Sometimes i'll just crank on it till the battery dies and nothing.  Other times its will crank and act like its going to start and if i give it a lil throttle it fires up.  No check engine codes or anything.  Its a big joke, now i have it ready to wheel and alll it want to do is play games. BULLSHITT!!!!
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
sounds like a dirty something rather.... airfilter clogged?
Thomas P
fuel system, the cheapest part is a fuel filter get a new one, if that dont work then you may need a fuel pump, i can get you a new one really cheap PM me if you need one i can get the best deal........
'14 Camry SE
ToYocRawleR
just replaced fuel filter, coil w/ msd, and wires.  Added a bunch of grounds and i know its not the pump because i can hear it on.  It starts with starting fluid and runs like a cat, just doesnt want to fire up on its own.
Rigs:
Thomas P
'14 Camry SE
sounds like a personal problem to me...
ToYocRawleR
The cold start is working i pulled it and gas is shooting out.
Rigs:
Ramrod
why do you want your truck that tall?
ToYocRawleR
Its not even that tall, im only runnin 4 " springs in the front and i have f100's in the rear w/ 2" block .  Its just enough to clear the 40's.
Rigs:
Ramrod
looks pretty ginormous to me, unless you consider "clearing" untrimmed and stock bumper
ToYocRawleR
Fully gettin it!!!!!...in my back yard!  :beerchug:
Rigs:
ToYocRawleR
Quote from: TEAM RAMROD on November 15, 2007, 10:42:26 PM
Sorry i guess its "ginormous" then.  And no i didnt want to start cutin :pokinit: if i didnt have to.  This is the 6th truck ive buit and i finally understand COG idea a lil better.  The back sags alot and will help it not to flop.  Dont bash on it yet, if you get your ass up here for lilbuddys snowrun you'll see whats up with it.
Rigs:
ToYocRawleR
still doesnt want to start on its own if any one has any suggestions let me know. thanks
Rigs:
lilbuddy
Quote from: ToYocRawleR on November 15, 2007, 10:48:14 PM
Hmmm just a thought and i doubt it will work cause you say you can hold the key in start and it wont start
but on my runner if i hold the key in the start position (not pushing in the clutch or anything) like to where its not turning over, hold it for like 5 seconds i can hear the pump run and then prime the fuel system and then it starts right up... if not it takes a little bit to start if i just keep turning it over.
RIP Kyota.... you are the man
GET IT!!!
86bobbedtoy
Are you going to bob it?
I think the 3rd gend look awesome bobbed 8-12"
The rig looks awesome.
Any other plans? exo paint etc etc?
ToYocRawleR
Quote from: 86bobbedtoy on November 15, 2007, 11:16:33 PM
Im definetely going to bob it, and fab some armor. First i just want to get it running.
Rigs:
Jud
Looks sweet! Thanksgiving is gonna be raw!
"bout tree fiddy"
Thomas P
looks bad ass imo, it is a little taller than my truck when i had those tires, but i had to cut and i still rubbed, i dont think its much bigger you should be fine.......
'14 Camry SE
DTB
 :yikes: :yikes: :yikes:
what are you doing to that poor yota??
86bobbedtoy
DTB
that just aint right....at least pick on a ford or jeep or something...not another toy  :rofl2:
86bobbedtoy
ToYocRawleR
Rigs:
ToYocRawleR
Got it runnnin ended up being a bad distributor.
Rigs:
