Author Topic: 3vze water pump HELP!!!!!  (Read 5691 times)
yota_krawler
  • Cody Hunter
  • Male Posts: 3,379
  • proud parent!!!
« on: Oct 14, 2007, 12:22:29 PM »
i am in the middle of changing the water pump on my v6 runner, I am stuck and wondering if there is a thread on how to change it or if anyone knows? It will be a big help please Thanks Cody
Willy Mammoth
  • Male Posts: 4,252
Re: 3vze water pump HELP!!!!!
« Reply #1 on: Oct 14, 2007, 12:30:05 PM »
I can't think of one, but what questions do you have?
cam011
  • Male Posts: 81
  • Member since Apr '07
« Reply #2 on: Oct 14, 2007, 01:05:07 PM »
Pretty much the same as doing a timing belt job, just another step or 2. Any write up on doing a t-belt has almost all the steps you need.
http://toyota.off-road.com/toyota/article/articleDetail.jsp?id=186574
http://www.yotatech.com/f2/2nd-gen-3vze-engine-r-u-thinking-doing-timing-belt-water-pump-my-observations-32812/
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #3 on: Oct 14, 2007, 05:43:41 PM »
I did mine last Dec, it isn't too hard.  :thumbs:  what're you stuck on, I can give you a hand :thumbs:
BTW, go ahead and change your timing belt too, might as well while you're in there
              -Ronald Reagan
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
« Reply #4 on: Oct 14, 2007, 08:23:14 PM »
you can do it really selfexplanatory.  Just make sure to get the timing right,  I did it once and I had no problems really easy.  I got faith in ya you can do it.
yota_krawler [OP]
  • Cody Hunter
  • Male Posts: 3,379
  • proud parent!!!
« Reply #5 on: Oct 14, 2007, 09:15:49 PM »
I got the black cover off and now I am stuck.
86bobbedtoy
  • Male Posts: 3,938
« Reply #6 on: Oct 15, 2007, 09:38:11 AM »
on what?  yes you have to remove the timing belt.
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #7 on: Oct 15, 2007, 06:12:04 PM »
which one?  the outer cover or the inner cover?
I'm assuming that you've already pulled the fan and radiator right?
did you look at both the links offered?  they were pretty clear to me.  What specifically are you stuck on? :dunno:
« Last Edit: Oct 15, 2007, 06:19:26 PM by BLACKDOG »
              -Ronald Reagan
yota_krawler [OP]
  • Cody Hunter
  • Male Posts: 3,379
  • proud parent!!!
« Reply #8 on: Oct 15, 2007, 10:13:46 PM »
sorry, I got the radiator pulled and all that, and took off that black cover that hides the timing belt and dont know what to do after that, what do you take off to get the the pump
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #9 on: Oct 15, 2007, 10:34:35 PM »
You need to pop the tensioner spring of the timing belt tensioner, and then remove the timing belt. Before you do that, set your timing @ TDC.  your crank pulley mark will line up with 0* on the marking thing (about 2 o clock on the crank pulley) and then cam marks should both line up with the marks on the rear timing cover (straight up)  if that isn't the case, spin the motor by hand using a ratchet on the crank pulley until they all line up. You'll also need to remove the PS pump belt, and the alternator belt.
After the timing belt is off, you'll have to remove the fan clutch and bracket assembly.  By this time you should see right where the water pump is (t-stat housing that the radiator hose goes to is part of it) Remove the other stuff that is in the way (don't remember exactly what else there is) and pull it out and replace it.  While you're in there, I would strongly recommend replacing that timing belt.  To do that, you'll have to pull off the crank pulley, and take off the lower timing belt cover.  if you screw up the alignment of the timing marks pulling the crank bolt off (its difficult to get off), don't worry, just make sure the mark on the crank, and the marks on the cams are all lined up before you put it all back together.  :thumbs:
Hopefully that wasn't too confusing.  Make sure you clearly mark where your bolts came from, and how they are to go back in :thumbs:  I believe the waterpump itself has 2 different sized bolts, and you have to put the right length bolts in the right places.
Feel free to PM me if you need more help, and if you can take pics, those will allow me to help you better if you get stuck.  I'm telling you this from memory, so a pic will certainly be a refresher. :thumbs:
              -Ronald Reagan
yota_krawler [OP]
  • Cody Hunter
  • Male Posts: 3,379
  • proud parent!!!
« Reply #10 on: Oct 16, 2007, 12:24:11 AM »
cool thank you I will get back on it tomorrow if it is not raining.  :crossed:
Last post Jun 20, 2006, 09:32:30 AM
by Mike D
Last post Jun 21, 2006, 08:50:33 PM
by BUDDERS
Last post Dec 18, 2006, 12:58:31 AM
by mikerob
Last post Apr 13, 2008, 10:24:45 PM
by kneedownnate
Last post Nov 14, 2023, 09:16:17 AM
by RUGER
