Redline MT 90 - What has been your experience?
Started by blackdiamond, October 05, 2007, 10:07:01 PM
blackdiamond
I recently had my transmission rebuilt (89 4Runner) and soon after put in some Redline MT 90.  Maybe I was expecting too much, but I wasn't that impressed.  I developed a leak after changing the engine and transmission to synthetics and after changing the engine to Valvoline Maxlife Blend 10w-40 and seeing no difference in the drips I opted to change the transmission to Valvoline 80w-90 blend today.  I can't tell any difference between the Redline and the valvoline, both seem to work equally.  The Redline is essentially a single viscosity oil theoretically eliminating the "thick" oil in cold temperatures, but in the mid 50's I see no difference.  I still have the Redline stored in a container in case I realize that I'm a fool.
:dunno:
UKMyers
Worked awesome in my R-150. Got rid of all the notchiness when it was cold.
Tallchevy
When I had my NV3500 for my Chevy rebuilt, The tranny shop recommened Redline. I did notice a difference when shifting, seemed to go into gear easier but then again it was just rebuilt.
87 4Runner redo
blackdiamond
Quote from: UKMyers on October 05, 2007, 10:26:34 PM
Have you ever run any synthetic blend gear oil for comparison?
I know the Redline is a great product, I'm just not convinced, at this point, it was worth $10+ per quart when the blend was about $5.  My reason for taking it out wasn't because I was unhappy with it, I just want to eliminate the leak and I suspect the transmission is where it originates.
UKMyers
No went straight from conventional to that. It only takes a couple quarts. Just do it and if you don't like it move on.. $10 a quart is too much for Redline BTW. Lots of people run Amsoil and Royal Purple too.
Plekto
I've never had a problem using normal oil, actually.  The real problem is that people leave the oil in there for silly periods like 50K miles or more(if they change it at all that is).  There's a bit difference between can last that long versus cheap and easy to change every year or two.  Kind of like motor oil or antifreeze.  You could get most oil to last 5-10K between changes, but it's so cheap that 3K or so is good preventative maintainence.
My rule of thumb is to use what the engine had in it originally, mostly because ancient gaskets and so on might not play well with synthetics.  You never know until you change, but not changing is cheaper and you know it will still work.
blackdiamond
Quote from: UKMyers on October 06, 2007, 09:40:32 PM
There is only one place here that carried Redline products, I don't think they do anymore, and I couldn't find any better price online with shiping.  Amsoil and Royal Purple are great synthetic products, but the single viscosity property of the Redline makes it a different product.  Redline gear oil would be closer to the other two.
I'm starting to run the blend gear oils because the synthetic portion is Group IV (PAO) which allows them to use less viscosity modifiers.  The result is better resistance to viscosity break down.  As far as I know there isn't any Group III gear oils on the market.  The price difference is minimal.
blackdiamond
Update - The leak turned out to be the head gasket near the back of the head causing oil to run down both sides of the bell housing.  It started to really show on the dipstick before I got it identified and fixed.  Since I removed the Redline MT90 I have noticed a minimal difference with the exception of one thing.  With the Redline MT90 in the transmission I was able to shift gears in low-low (2.28 x 4.70) without the clutch with ease.  With the blend, it will still shift, but it certainly isn't as smooth.  The Redline obvioulsy has an effect on the syncros and I'm planning to put the Redline back in since I didn't get rid of it.
88_Pathy
So hold on... Is the Redline a full synthetic or a blend?
blackdiamond
Quote from: 88_Pathy on November 29, 2007, 08:29:33 PM
Redline MT90 is a full synthetic.  It's "special" feature is the fact that it is essentially a single viscosity so it works that same at all temperatures where dino and blend are "thick" at cold temperatures.
Interesting.  I can tell you the one thing that keeps myself and many others running redline synthetic engine oil (though this is supposed to be a trait of any synthetic) in our high performance, high rpm street bikes.  A synthetic 20/50 will flow to the top end quicker when cold than a lighter weight dino oil.  My oil never looks dirty when I change it in the bike either, used to run it in the truck after I pulled it out of the bike :_oops:
