TEAL '85 extra cab build...
Started by SolidAxle, September 28, 2007, 09:32:09 PM
I.D.G.A.F
yeah, I want two aussie lockers myself.
SolidAxle
Quote from: jkief86 on April 21, 2008, 12:38:18 PM
It's hard to tell if the shroud is touching the radiator.
sorry for my ignorance, the fan shroud makes contact at the top and bottom tanks and just lightly touches the fins. (the "gasket" thing squished to the tanks and kinda sticks out to just barly reach the fins)
SolidAxle
 :teeth: Today my dad phoned me from work to tell me that there was an '89 rear axle assembly for sale  with 4.10's and an aussie for $250.  :yupyup: I'm going to look at it on thursday. its apperently been in the third for 2 months, but the guy said the 3rd may need a new crush sleeve (pinion). Hopefully its fairly easy to remove and install in my 3rd (4.30's).
Must do research to make it sure it is in fact an aussie when i go to look at it  :turtle3:
jrock
Nice find, or your dad's find haha. Thanks for the fan info.
twistedtoy92
I.D.G.A.F
sweet hunk of metal, was it hard to install?
SolidAxle
actually, I uninstalled it  :cheese:
I bought it in a 4:10 third that needed a new pinion bearing, not sure wich one and a crush sleeve. My truck being auto has 4.30 gears so i figured i would just swap it out into my 4.30 differential. Based on the uninstall, if you remember to mark where everything goes it should be cake.
On a side note, my engine began to not like to idle. swaped throttle body, runs smooth, now worse idle. so more screwing around tomorrow after school. I also replaced brakelines from the t fitting to the rear (no lspv) and along the axles, replaced a wheel cylinder and unstuck my ebrake in like 5 places lol.
I.D.G.A.F
SolidAxle
#131
Quote from: I.D.G.A.F on April 28, 2008, 02:40:09 AM
sweet, how much was the aussie usesd?
I bought the whole third for $250 locker was 2 months old. and looks it.
Still having trouble with my motor :mad: going to try swaping the two temp sensors on my intake and make egr block off plates tomorrow.
I.D.G.A.F
sweet, was that motor relatively stock or was it bored over and what not?
SolidAxle
Motor is old block (domed top pistons) its 20 over with comp cams 252s cam, and lce header and efi either than that its stock.
got this done today but i have to work so i'll finish them tomorrow. 3/8's plate i think lol :flamer:
THATS THICK!
i think 1/8in is just fine... nice OVERKILL :beerchug:
SolidAxle
Quote from: that HO kid on April 29, 2008, 01:31:40 PM
THATS THICK!
It was all we had at my school, its about the same thickness as the flange on the EGR.
tom w.
SolidAxle
FIN.
And the best part about removing the egr is you get rid of all this  :pokinit:
Duffil
on the diff...why would you pull the aussie out of the carrier instead of just swapping carriers...way easier.
isnt there 3 places you need block off plates? LCE sells the kit and it has 3 plates..
Jud
"bout tree fiddy"
tom w.
Quote from: that HO kid on April 30, 2008, 10:38:31 PM
Nope... unless the third plate has something to do with a CA truck.
Quote from: tom w. on May 01, 2008, 09:31:11 AM
i think the kit has three cause one is for a Carb'd truck and the other is EFI.
nevermind. :gap:
SolidAxle
Quote from: Duffil on April 30, 2008, 10:34:21 PM
I took it out of that third because the pinion bearings were in rough shape AND it had 4.10s... I have 4.30s
Quote from: that HO kid on May 01, 2008, 10:31:21 AM
nevermind. :gap:
You are correct sir
Quote from: Jud on April 30, 2008, 10:56:32 PM
Good work buddy
Thanks.
ajordan1975
SolidAxle
Thanks for all the compliments.cookies for HO
Went out to my aunts today to steal my 31's back off my dads old truck (black 1st gen runner)  and nded up also stealing coolant sensors, throttle body and air box lid w/afm pics tomorrow, its like midnight where I am. I almost forgot how boss it looks even with just 31's, going to bring them into school and switch the tires onto a set of factory chrome wheels. :bling:
Quote from: 4runner666 on May 01, 2008, 08:42:03 PM
:afro:
SolidAxle
I DROVE IT... on sunday. ITS WORKS AWSOME...like it should.
to make it run right, and make my throttle cable work i swapped in yet another throttle body (off my dads black truck as well as the two coolant temp sensors for the cold start injector.
in progress.
Sorry i don't have any video of it driving. hopefully i can get some up soon, it sounds sweet. so these mall crawler posers of it in my driveway will have to do haha.  :hammer:
OH i had one minor problem also, the distributor bolt came loos and fell out. not a big deal the distributor itself didn't move but oil sprayed all over the drivers side  :willynilly:
AND i got the factory toyota wheels cleaned up with michelins on them for now.
