what a beautiful engine
Started by fatt_matt, September 25, 2007, 04:20:32 PM
red
theres another video where the truck is run much longer. ends up with only 2 working cylinders, no oil, too many holes in the block to count (you can see a piston moving), and for the finishing touch the guy puts it in gear and pulls into the garage under its own power.
read and comment :whip:
USAF EOD tech
unclejpl4x4
fatt_matt
Jeep
blackdiamond
Anybody want to buy a domestic?   :yikes:
red
if it has a gm 350 or 4.3L gasser i would. or a ford 302 if i stuck with gas. diesel, ford 7.3, cummins 3.9L 4bt or 5.9L 6bt with mechanical injection i would in a heartbeat.
with a 4cyl i'd go toyota or nissan always, indestructable little turds hahaha.
USAF EOD tech
