I saw a guy with 2 non-steering axles (one in the front, one in the rear) and airbags set up for skateboard steering. Yes it worked.
thats crazy. wouldnt that cause alot of body roll like a sk8??
I searched this forum and a couple of others and could not find anything about this. I know this may sound a little crazy is there any one out there using rear axles as their front axle?
I see the buggy is switching out the axles and it looks like the pumpkin is being set closer to the wheels.
The reason the rear axle is off set so much is the engine is in the back, facing backwards. The real axle is being driven by the front output on the t-case and the front axle is being driven by the back output. This design has been around for a while one of the first to use it was "Tiny' an air-cooled VW engine powered buggy that took first place in just about all the comp events a few years back. It was driven by Jon the owner of All-Pro. The new axle housings that are under the Buggy look to be Diamond axle housing and are designed and built by Biran at Front Range Offroad. You can learn more about the housings here.http://www.diamondaxle.com/index.htm
Started by 4Runnerguy General 4WD Discussion
Started by zippo Parts Wanted
Started by 79coyotefrg Parts For Sale
Started by 88-4skinner Toyota Pickup/4Runner Tech 1979-95
Started by lownlinked85 Parts For Sale
