Sold: Built 91 4runner- Sacramento
Started by johnnygalt, September 18, 2007, 10:37:04 AM
johnnygalt
For every season turn, turn...and it's the season to sell my 4runner.  Another kid on the way means I won't have time to wheel or wrench for a few years and it would be a shame to let this rig serve just as a street machine.  Details:
UPDATE 11/20:
New Price:  $8,000 OBO
Replaced wheel bearings, trunion bearings and related seals w/ Marlin's rebuild kit.  Set the preload to 12lbs per side.  Found out I had the drag link and tie rod reversed on the steering arm :shake_head:  The death wobble seems to be gone.
General
   1991 4runner: 5spd,~142,000 Miles, 3.0 V-6
   4 door, black, Herculined on the exterior approximately halfway up the side around the entire truck.
   Body is pretty straight, no dents, a bit of waviness on the passenger fender.  This is NOT a show truck.
   Power everything: locks, windows, antenna, alarm, all work.  CD player, CB.
   Interior is complete, clean, but shows 16 years of use.
   Rear tire carrier, modded to raise spare up ~ 3"
   Factory roof rack
   SAS
        Recent muffler + tailpipe
   Factory Service Manual
   Crappy Haynes Manual
   50% 35" MTR's on black wagon wheels, full size spare
Engine
   Stock 3vz3 V-6.  Engine was replaced ~90K miles by Berkeley Toyota after the 3rd headgasket set failed.  It's a little unclear if the entire engine or just the block was replaced (I'm the second owner).  Runner has ~142K miles on it now but odometer is off due to tire and gear swaps.  Passed smog last year with flying colors and I will smog again for the new owner.  Good power for a 3vze.  Has a mystery oil leak I haven't bothered to track down.  Plugs, wires, rotor, cap and large hoses were replaced within 10K miles w/ OEM Toyota.  Coolant was flushed at this time, filed with distilled water and green coolant.  Runs great, no issues, has never run hot or overheated since I've owned it.
Drivetrain
Transmission Stock 5spd filled with Redline MTL.  Once in a great while it pops out of first gear.
Dual cases Below was installed in March of 2007 and has maybe 3000 miles on them (except for the stock chain drive case)
   Marlin V-6 adapter, gear drive reduction box/case rebuilt and prepped by Marlin.
   MC10-R10 gear drive to chain drive case adaptor.
   Stock chain drive case(replaced the seals).
   3/8" steel Turtle skid plate customized for the above.
   Dual case mounts
Driveshafts
   Front is 8" travel, clearanced Toyota double cardan (CV) retubed (.095 wall) by Sac Driveline Service.
   Rear is stock travel, clearanced Toyota double cardan (CV) retubed (.095 wall) by Sac Driveline Service.
   One of these has new u-joints(US brand) and CV bearings.
Front Axle
   Toyota E-Locker High Pinion Dif.
   4.88's from All-Pro that are sourced from one of Toyota's gear cutters in Japan.  Gears were sent to Bobby Long for Cryo.
   Stock birfields re-heat treated by Bobby Long.
   Trail Gear wheel spacers
   Trail Gear rock rings (extra thick knuckle felt retainers)
   Marlin HD axle seals.
   ARP knuckle studs
   Knuckle seals, gaskets, etc have maybe 15K miles on them, from Marlin.
   Stock Aisin hubs.
   84-85 front axle, trussed on top.
   FJ-80 Rotors
Rear Axle
   Toyota E-Locker Dif w/ 4.88's.
   Mount for antiwrap bar with captive nuts.
Suspension
   Rear:  F150 56" hybrid leaf packs.  10" Bilstein 5125's with EVA bumpstops.  Shocks are mildly / \ .  5" Foothill Offroad Shackles.
   Front:  Rancho Waggy Springs w/ 2500 miles on them.  12" Bilstein 5125's.  Trail Gear towers and bumpstops.  5" shackles.  Trailgear front spring hanger.
   Antiwrap:  2 point mount at rear axle using Toyota panhard rubber mounts, front uses adjustible 5/8's spherical rod end to shackle.  Built from 2" square tubing.
Brakes
   Replacement new OEM Toyota master cylinder ~ 25,000 miles ago.
   Summit proportioning valve.
   Rebuilt V-6 calipers
   FJ-80 Rotors
   Stainless flexible brakelines, spring retained.
Steering
   Trail Gear High Steer.
   Non Trail Gear tie rod ends.  I bought some Japanese 555 brand.
Armor
   Homebuilt sliders.  2x3 box tube under rockers, 1.75" round tube as step.
   Rear bumper: 1.75" round tube wraping around rear quarters, with step, 2" receiver tube for accessories (DEFINITELY NOT RATED FOR TOWING)     Integrated recovery points for 3/4 D-ring shackles.
   Trail Gear front winch mount not installed.  I was going to use this as a basis for a custom front bumper.
Spares
   Complete 84/85 front axle assembly (disassembled).  Includes birfs, inners, hubs, spindles, knuckles, etc.  No 3rd member.
   Rear axle housing, inner axles with backing plates.
   IFS Steering Box (leaks)
   Soft brake lines + front hard lines
   Chain Drive Transfer case (works fine)
   Tailights, Corner lights, front turn indicator
   Coil + Ignitor
   Used hoses, belts, u-joints
The Good:[/b]
   See above.  I built this like I was gonna keep it forever.  Will do 75 on the freeway no problemo.  Comfy to drive, A/C, power everything, very capable.  Took it thru the 'Con during that snow/rain/sleet weekend in september and it walked thru everything.  Almost boringly capable.
The Bad:[/b]
   I built it.  So you inherit my welds.
   Gas mileage.  15 on a good day, probably less.
   On the right undulating road at a very low speed (5-10mph), I get a very rare death wobble that I can accelerate out of. (See Above)
   Marginal body work in a couple places.  You can see a slight wave in the driver door, passenger fender and driver rear wheel well.  Hood has a slight tweak as well.
   ABS has been disconnected and will never work again.
   It's a 16 year old 4runner on big tires that handles and stops poorly like any big truck would.  Drive accordingly.
   I cut one rear wheel and need to cut the other one to match.  I'll do it or the new owner can.
Asking $9000 $8,000 OBO.  I did a spreadsheet showing what I'd get if I parted it out and came up with about $8500, which I'm willing, but would prefer not to do.  4runner is in Sacramento area.
fatt_matt
brutally honest.. i give it to you.. you will have good luck on sale.. also put on craigslist.. it'll sell faster there.. usually does
any pics??? of it clean on the street, are usually good as well. wheeling pics work as well.
Jeep
johnnygalt
Quote from: fatt_matt on September 18, 2007, 10:42:06 PM
;)  Golden Rule.  I've never had anyone call me after I've sold them a vehicle.  I'd rather sleep well at night.
johnnygalt
johnnygalt
Thomas P
love the license plate covers,  :beerchug: nice trunk and good luck.....
'14 Camry SE
SCX10 Honcho on roids!
johnnygalt
Quote from: bajabooster on September 19, 2007, 09:17:51 PM
oh and doas e locker stand for electric??
Yes- e-locker = electric
Don't butcher grandpa's Tundra.  Leave it stock as your daily driver and buy an 83-85 solid axle pickup with a beat body.  It will be a much cheaper learning process for you and you've got memories of taking trips with him in that truck.
Re. Francis- rent the movie Stripes.
bajabooster
John Doe
johnnygalt
John Doe
johnnygalt
Interior pics:  Driver side door panel is representative of all door panels, great condition.  Driver seat shows normal wear on side panel.  Passenger rear seat has about 10 inches of stitching that has come undone, can be easily fixed with needle and thread, I just haven't gotten around to it.  Those are the only flaws with the interior.  Aluminum panel below radio holds the switches for the e-lockers.  The rear transfer case shifter is located in what used to be the small "cup" below the armrest.
ROCKO
#12
ARE YOU WILLING TO TRADE FOR A 2001 CHEVY S-10 SHOWTRUCK ON BAGS NO HACK JOB BED EVERYTHING HIDIN' 36000 ORG. MILES ITS A NICE TRUCK NEVER DRIVIN IN THE RAIN. I HAVE PICS I COULD SEND OR LOOK AT MYSPACE.COM/IROCKCRAWL THANKS
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
johnnygalt
Quote from: ROCKO on November 27, 2007, 07:30:39 PM
Thanks for the offer, but I'm looking for a family hauler.
ROCKO
Quote from: johnnygalt on November 27, 2007, 07:47:15 PM
cool thank you nice rig
F@$K CANCER
Marc P
Sweet runner...good luck with the sale. Its a great deal. I have way more $$ into mine, and you have more goodies.
1998 4Runner--under construction
johnnygalt
88_Pathy
johnnygalt
Quote from: 88_Pathy on December 12, 2007, 12:20:18 PM
Sold yet
Passed smog today with flying colors, I'll know in a couple days if my buyer follows through.
fatt_matt
Quote from: johnnygalt on December 12, 2007, 10:50:14 PM
did they?  ...
Jeep
