Line lock kit
Started by ohioyota, September 08, 2007, 11:32:43 AM
ohioyota
Any one know of a place that sells a line lock kit with metric fittings that will work with toyota brake lines.
Willy Mammoth
Nope, but you can change the line nuts and re flare. If you just want to hold the line pressure for a few seconds they are ok, but much more than that they will burn up. I had this problem with mine when I tried to use it as a E brake. You can get manual valves if you are trying to us it to work like a E brake.
big ron
you have a link to the manual line locks :gap:
Willy Mammoth
Quote from: big ron on September 08, 2007, 05:21:27 PM
I will look and see what I can find, but I am finding it hard to concentrate.  :drooling:
ohioyota
My buddie has one on his crawler he uses it as an ebrake as well as cutting brakes and he hasnt had a problem with it. his is the kit from summit i think. i guess ill just have to cut and flare the lines
ohioyota
Here I stole this from yotadork83's post in project research.
http://www.spidertrax.com/s.nl/it.A/id.620/.f?sc=2&category=81
Its a manual line lock
