Author Topic: Fuel cell, Line lock question  (Read 2054 times)
ohioyota
  • Turtle Points: 2
  • Male Posts: 212
  • Member since May '06
  • GIV-R-HELL
« on: Aug 30, 2007, 09:40:40 PM »
What is a good off road fuel cell? Are there any out there that allow you to use a stock toyota intank fuel pump and sending unit?
Also does any one run line locks on their rig? Pics? Are they basicaly like an e brake that goes to each individual rear wheel. Is there any place that sells a kit?
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Member since Oct '04
  • Proud Parent
Re: Fuel cell, Line lock question
« Reply #1 on: Aug 30, 2007, 09:55:33 PM »
I've got an RCI fuel cell, not bad.. I had to put rubber under the mounts to keep the welds from cracking but other then that it has been great.
Dunno about the internal fuel pump because mine's on an 82'.. mechanical fuel pump @ the block.
ohioyota [OP]
  • Turtle Points: 2
  • Male Posts: 212
  • GIV-R-HELL
« Reply #2 on: Aug 31, 2007, 10:43:27 PM »
how does it do on angles? does it have a drop sump?
Halladay
  • Member since May '09
  • HALLADAY
« Reply #3 on: Jun 05, 2009, 11:31:06 PM »
i need to know the same. my tank is so rusty it colgs my injectors with rust and i hate gas tanks because they are boat ancors
COToy91
  • Turtle Points: -21
  • Male Posts: 1,241
  • Member since May '07
  • Rollin on 37's
« Reply #4 on: Jun 05, 2009, 11:32:54 PM »
electric or manual line lock?
the only reason i would use one is if you converted to rear discs and no longer have the stock ebrake. They basically keep pressure on the pads after your foot is taken off the brake pedal, theoretically giving you an ebrake. I would not suggest this as you main ebrake as the do fail and hit does happen.
Electric one operate as always closed till 12 volts is applied OR always open till 12 volts is applied. The first would allow you to use the line lock without draining your battery. The second would be set and drain your battery and then release the brakes...
Manual ones are basically a ball valve operated by you, depress the brake turn the valve and then release, result is a ebrake...kinda
As for who sells a kit
http://www.downeyoff-road.com/ChassisComponents/DiscBrakes.html
but it is overpriced and i am sure you could scrounge the parts together for cheaper
« Last Edit: Jun 05, 2009, 11:46:03 PM by COToy91 »
COToy91
  • Male Posts: 1,241
  • Rollin on 37's
« Reply #5 on: Jun 05, 2009, 11:53:39 PM »
http://www.jamarperformance.com/Store/Details.asp?ProductID=30
better price, just convert it to toyota threads or re-flare some SAE fittings on
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #6 on: Jun 05, 2009, 11:56:26 PM »
IF u skimp on one thing on your truck it should not be the fuel system....
Pricey...yes....safe....no doubt if used correctly...
Quote
Last post Jan 01, 2005, 07:17:14 PM
by ezthere
Last post Mar 31, 2005, 07:34:15 PM
by alwayzbroken
Last post Jun 01, 2006, 11:39:49 AM
by ohioyota
Last post Jun 24, 2007, 06:25:01 PM
by ~tc~
Last post Aug 30, 2007, 09:09:58 PM
by ohioyota
