Double T case??
Started by SLIVER, August 20, 2007, 07:24:15 AM
SLIVER
So I am a newbie when it comes to the double T case thing. My question is when running a double T case does it make all of the gears, even hi range, twice as low?? How does it work exactly? I just put 5.29's in with 35" tires in a 85 4runner with the 22RE and now my top speed is 65. I already bought the MC07-R10 adapter and want to do the upgrade, however this truck is a DD and I want to be able to drive on the freeway.
Please enlighten me.
Thanks a ton
))--SLIVER-->
))--SLIVER-->
MiniSimp
Everything stays the same, unless you shift it lower.
Normal driving is still 1:1
Possible gear options:
1st-high-high (normal driving)
1st-high-low (normal low)
1st-low-low (double low)
SLIVER
Thanks MINI! That's what I thought but I just wanted to be sure before I did the swap.
))--SLIVER-->
))--SLIVER-->
65 is  all you got :ack:  dude, stay out of 5th,   man  that  motor must be tired  :screwy:
bigarms23
My 4runner has chevy axles with 456 gears and i have dual cases with 228in first box and 5.0in the second and i still can go 90mph on the freeway
dual 2.28's  and can still  peg the speedo
SLIVER
GEEZE, Sounds like I should be able to go faster huh? My motor is tired and uses quite a bit of oil. Definitely needs a rebuild. That will be coming soon!!
))--SLIVER-->
))--SLIVER-->
