Winch mounting holes?
Started by Thumper, August 19, 2007, 06:20:49 PM
Thumper
Hey does anyone know of a web site that has a printable template too use for drilling the holes for mounting a winch?
Thanks
adam
SrOrangeCrawler
I used a ruler for mine, when I mounted it.
1987 SAS Pickup ExtrCab
i believe the footprints are the same for all winches until you get into the huge ones... its pretty universal.... can you mock up your winch you plan on using? you wouldnt wnat to mount the templete, then drill it all out, to discover your winch will hit your radiator support and needs to be moved, or something like that
Tallchevy
You can use some butcher paper, a pencil or pen & a small ballpeen hammer. Tape the paper to the winch covering the mounting holes. The use the pencil & poke the bolt holes out. After you get an idea of were the holes are, you can use a small ballpeen hammer & lightly tap the outer edge of the bolt holes. The ball end of the hammer will cut the paper around the hole. I have had to make gasket before & this is how I do it. Practice on something else so you get a feel for it. Be careful not to damage the threads  :crossed:
87 4Runner redo
Thumper
allright endend up searching and found the mounting hole specs its 10 by 4 1/2 inches and got them drilled.
thanks
ill post up what the bumper turns out looking like.
adam
Hottrod81
Use your winch fairlead as a pattern.
Tallchevy
What size is you winch & how thick is the winch mounting plate?
87 4Runner redo
