did they have a xcab short bed because i thought the xcabs all had the short bed
buckets? if so how much?
how much fo the drive lines and inner axels
how much for the t case
what is the gear ratio
where in nm im in tucson
im a newbe from tucson heres my rig 85 xcab sr5 22re with 4:88 gears, lock right rear, 35 12.50 15r bfg muds, 3in wheel spacers.the rears are chevys with 3in blocks and 4* shims, fronts are pro comp 5in but that is temp only till i get $500 to go xover and then the packs i built out of my rears and some waggyswill be in. it has a 3in body lift i know it crap but is only so i can lift my drive train and get rid of that damn crossmember. enginebuilder cam, pace setter header and 2 1/2 in all the way with a 40 series flowmaster making it sound like a big block. in the pic im not quite flexed out in the rear and no ever close in the front
