Winch mount problem
Started by Tallchevy, August 16, 2007, 10:02:26 PM
Tallchevy
I know someone that has a winch & is willing to sell it to me. It's a Warn 12,000lb  :thumbs: The problem is the front mounting bolt that go into the aluminum housing have been cross threaded, actually 3 bolts  :thumbdown:. I'm sure a heli coil kit would be good enough since the bolts hold the winch in place, & winching in a straight line should be fine. The conceren I have is if I have to winch at an angle. What do you think?
87 4Runner redo
emsvitil
How much aluminum is around the hole?
If there's plenty of aluminum, I'd do a threaded insert (case saver) and it would most likely be stronger than original.........  (A threaded insert is slightly bigger than a helicoil, but has the advantage of using normal tap sizes, not the special helicoil taps)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
harley1615
you can drill them out and go bigger I have done it before and it holds up just fine!
MiniSimp
Drill them out and use a nut.
