help with chevies(pictures) and a few other things
Started by Jakesteads, August 15, 2007, 02:22:07 PM
Jakesteads
ok so i decided to go ahead and do my chevy swap.... i know about the 11" forward for the mount..... problem is i had all ready cut my mounts off a few days ago without even thinking... so from the end of where the old mount is 7.5"
this is what the rear looks like with no shackles....
this isn't bolted down or anything its still really rough here are how my springs are sitting as well
and also driveshaft extension
im not really looking for answers id like to think im somewhat on the right track....
now secondly the metal supplier here locally does not sell 3.5 x 3.5 anything... so i went through their junk pile and found some 4x4 1/4...
My question to this is can i run this and then use washers as spacers for the springs or is this a bad idea all together?
ok last just a few pics of the truck its an 85 4runner EFI stock with 33's welded rear diff marlin dual case skid rockers waiting to be installed
and here it is right now in the garage
I like Toyota
MiniSimp
Hope this helps with the front hanger location, as for the rear, I mounted mine 5" back with a 5" shackle.
Tallchevy
Since having a smooth frame isn't high on my list, I measured mine. 8" from the front most part of the hanger. Also, if you still have the parts you cut off, just tack them in place & measure.
87 4Runner redo
Tallchevy
I used 3"x3"x 1/4", cut & welded the angle so that the hanger is 3 1/16" for the spring bushing, then welded them together. Also used 3"x 1/4" plate & made a skid for the hanger.
87 4Runner redo
Jakesteads
wow thanks for the help so far... the 3x3 is a good idea the 4x4 i got is so big it will really be an anchor....
tall chevy thanks for that i can move my rear axle up some.... to adjust it... tomorrow ill have my shackles made and ill bolt that end up...
ill also go back and grab some 3x3 and see what i can do with that 4x4 is just too big....
how much slip does the rear shaft have?
I like Toyota
Tallchevy
Here is a pic of my hanger.
87 4Runner redo
