0 Members and 18 Guests are viewing this topic.
http://www.superbrightleds.com/products/car
I've got the http://www.superbrightleds.com and they are AWESOME.I went with their ALM-x6 6-led oval units instead of the more expensive Luxeon ones because I can get a pair of the ALM-x6 for the same price. They are very bright and only draw 0.025 Amps. I will have them all set up by the Round up Regarding Round-eyes, I don't know why so many people like that company. They are over priced: They sell the Luxeon lights for $30 whereas http://www.superbrightleds.com sells the SAME EXACT THING for only $19.95!If they were better then I could understand. Otherwise that is straight up robbery in my opinion.
that link dont work
Yes.And with H3 bulbs, it would be wise to use a rely if using 3 or more lights on the same (standard plastic) switch.I ran 4 H3 halogen rock lights through a nice big KC Highlights switch, and I melted and fried the switch!So each bulb I am using is 55 watts, or at 14 volts, that would be almost 4 amps each. I was running 4 bulbs through the same switch, so 16 Amps was too much for one switch.Now to compare this with these little LEDs that only draw 0.0038 amps each (0.023 amps / 6 LEDs), you could run 4,210 LEDs per switch before you melt it! WOW! Your entire truck would be glowing!! And that's only on one switch and one circuit!!
I did some reading and the 1 Watt Luxeon Emitter is eaqual to 10-20 ultra-bright white 5mm LEDs
there is a user named robinhood4x4 over on ultimateyota.com he has a pretty slick writeup on hishttp://www.ultimateyota.com/index.php?option=com_smf&Itemid=26&topic=175.0
I was going to say the Luxeon must be brighter. I have not tested the two and I didn't know what to order at first, so I just got a pair of the 6-led setup. I figure I can get two of these for the same price as on Luxeon, and maybe I can spread the light around a bit more?I should just buy a Luxeon and compare the two for a final decision.
Well, if the ideal of excluding the lesser equipped (stock or otherwise) is accepted... there is no fundamental difference between that and a Sierra CLub ideal of exclusion. If we cannot embrace the 4wheel users as a whole. We are not fighting for access. I cannot be that shortsighted
Sorry about the thread hijack...nobody but Bill Gates is gonna spend $46-$56 on these flashlights for use as rock lights
I wasn't accusing you of advising people to use these expensive flashlights as rocklights, oh Prince of Thieves...i was just apolgizing for hijacking the thread, and boasting of how good the flashlights are.
Started by Hyena « 1 2 » Project Research and Build-Ups
Started by rockhound Project Research and Build-Ups
Started by *** YELLER *** General 4WD Discussion
Started by H8PVMNT « 1 2 » General 4WD Discussion
Started by rockin86runner General 4WD Discussion
