yj help
Started by onecrazyblackredneck, August 11, 2007, 08:33:59 PM
Okay so I just  bouhgt a  88 jeep wrangler carburetored motor. So when I stop, it cuts off especially if I stop real fast. So is my carb getting to much gas or too little gas? I was thinking maybe it needs an electric fuel pump, but wasnt sure if that would fix the problem or not
99 f250 7.3 diesel 33" tires mildly built
05 mustang ground effects 18" wheels black on black
craziest black redneck youll ever meet
TacoStewie
you could have a vacume leak
4THEWKN
fatt_matt
ooooh.. you got the 4.2 YUMMM... great engine.. sorry to hear bout the problem, usually a very reliable engine. It's up there with my favorite engine behind the early L-head's and the buik v6 in the 65 cj5's..
i believe it is a vaccum leak. Is it every stop? or some stops, mostly aafter a downhill??
i don't think it is a problem with your carb. Cause i've heard of it happening to the 4.0fuel Injected. sometimes..
I dont think, an electric fuel pump will solve the problem.
Jeep
91 super yoda
check the brake booster vacum line. if its good, make sure its idling high enough to withstand the vacum surge when you hit the brakes.
95jeepyj
Yes it's a vacumm leak for sure....I own a 95 yj and does it at times
