metric nut and bolt strength
Started by TheTransporter, August 07, 2007, 06:01:31 PM
TheTransporter
so what is 8.8 equal to in american standard strength wise? :dunno:
you think nobody cares about you? try missing a couple of car payments.
its  8.8   meaning its  slightly  harder than grade 8
TheTransporter
somehow I don't think thats right.
Duffil
Nope sorry.  Metric Grade 8.8 is SAE Grade 5.  Metric 10.9 is equivalent to SAE Grade 8.
TheTransporter
no store that I have found carries anything bigger than 8.8. Where can I find stronger metric fasteners at? :dunno:
Duffil
Quote from: TheTransporter on August 07, 2007, 07:24:59 PM
well, I know any napa can order them.  Do you have a Fastenal or similar locale to you? Grainger?
TheTransporter
~tc~
Quote from: Duffil on August 07, 2007, 07:10:05 PM
That is correct. Note that JIS (Japanese) calls them Grade 8 and Grade 10 respectively.
Ace Hardware around here carries some 10.9, but mostly coarse thread, and if you're going into a factory hole, it's probably fine thread. I usually get them from Fastenal. The common size is M12-1.25x30mm IIRC - order A BUNCH, they are good to have as spares. Used for the CV flange to stub axle, brake caliper, tranny crossmember, and a couple other places (17mm wrench size).
Socket head cap screws are also available in a stronger yet 12.9, but I would be concerned about them being too brittle and actually fracturing easier in our type of usage.
'93 4Runner, V6/MT ARB's, armor, 33's, no lift!
President, CO Chapter TTORA www.cottora.org
emsvitil
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Duffil
Quote from: ~tc~ on August 07, 2007, 08:14:10 PM
:headscratch: JIS simply means Japanese Industrial Standard. A JIS bolt will have a smaller head than a typical metric bolt; ie: 14mm JIS vs 17mm STD. if by CV flange to stub axle you mean the spindle bolts, those are 10mm (14mm head) the caliper mounting bolts are 14mm (17mm head)
Quote from: 79coyotefrg on August 07, 2007, 06:03:00 PM
hmm  well  i know i had  sheered off a driveshaft bolt that was  us grade 8  and replaced it with a  stock toyota bolt with 8.8 on the head  and its never broke ,  well till i got my dual cases  and replaced them all with  the  same bolts Marlin sells  that i got from a 88 truck
oh well learn somethin new everyday
Duffil
Quote from: 79coyotefrg on August 08, 2007, 07:30:37 PM
that's because of the shoulder size on a toy driveshaft bolt.  a reg 3/8 bolt will have a little slop in it, and consequently blow apart when the flanges twist.
I had one of my customers do that:
him: Hey, Rex what size are toy driveshaft bolts.
me:  they have a special sixed shoulder.  go to the dealer.
him: Nope, I'll get some grade 8 from ACE hardware.
next day
him: hey, you know, I broke those bolts.  can you get me some from Toyota?
me: :rofl: :haha:
~tc~
Quote from: Duffil on August 08, 2007, 12:52:39 AMif by CV flange to stub axle you mean the spindle bolts
No, I mean the bolts (well, studs from the factory) that hold the CV flange to the stub axle flange. If you knock those studs out, and replace with bolts it makes changing CV's MUCH easier. The bolts you need are exactly the same as the caliper and crossmember bolts.
Duffil
Quote from: ~tc~ on August 08, 2007, 08:23:58 PM
What are you working on? sorry, but I am not following what you mean by CV to stub axle flange.  The only CV that I know of on an SA truck is on the front driveshaft.
TheTransporter
I think he is talking about an IFS truck.
Duffil
~tc~
Yes, I am - sorry for the confusion
TheTransporter
so are all the 8.8 bolts that hold the leaf springs on strong enough. I think they would be due to the size of them, but i could be wrong.
