other than WMS does IFS rears have a benefit?
Started by Jakesteads, August 07, 2007, 04:55:21 PM
Jakesteads
i have an 85 4 runner stock everything currently with 33's.... i ordered some spacers for the front because i get some minor rubbing..... other than the width of the axle(IFS REAR) is there something else that will help along the way...... brakes, shafts, etc?
or should i just run spacers in the rear?
I like Toyota
the 86 up  is  a heavier axle tube as well, and it has bigger drum brakes
if you dont have a axle lined up just get some spacers  for now,  you can always sell themlater
Jakesteads
so the shafts are same just bigger brakes.... and wider..... i can get a axle for around 100 bucks but i might just run spacers for now im not planning on going bigger that my 33's for awhile.... thanks for the response
I like Toyota
