What type of oil is best for W56 tranny.......beside what factory recomends
Started by 90TOYPU, April 20, 2004, 07:18:23 PM
90TOYPU
Marlin and Crew,
What type of oil do you recomend running in a W56 tranny? Synthetic? Viscosity?
Thanks,
Todd
HELLO
Marlin
We recommend 80/90 weight GL5 gear oil. Any brand as long as it is GL 5. This is the factory weight oil.
Synthetic [GL 6] is always the better choice.
Use the weight that is made for manual transmissio
Marlin
