Big T the T100 / R151 to 3.4l swap
Started by 854RUN, July 12, 2007, 08:27:57 AM
Toyin
I got a couple more questions for if you don't mind.
1st
What is your wheel base?
2nd
What is the frame heigth? Going to run trail gear springs in teh front and not sure what in the rear yet i would like to try and find some 5'' TC,MC or AP springs.
854RUN
Ask away
WB is 124" (stock)
ground to frame is 27". The rear springs are 5" Alcans and the fronts are 2" Alcans.
the front hanger: it drops 4 3/4" from the bottom of the frame to the center of the bolt. The spring hanger bolt is in-line with the body mount bolt.
My hood sits about even with the hood of a newer f150
What axle you wont to run?
let me know if there's any thing else. :)
-JOSH-
Toyin
I'm hoping to get the WB a little shorter :flamer: if  can. That seems like it's pretty loooong. I'm going to run a GM60 in the front and a 14B in the rear, tires will be a set of 40'' irocs :cool: on 17 MT aluminum wheels with staun internal bead locks.
You don't have any pictures of the inside of the bed where you made the cuts by the tail gate and the wheel well do ya?
854RUN
The WB is a little long but not as long as a taco (127")
if you do 5" springs in the rear with 40's you will need to do some trimming
i will see if i have any pic of the inside of the bed. no cuts in the wheel well's
-JOSH-
Toyin
Na i think that picture will work. I figured i would have to trim some but that's no big deal. Biggest goal is to keep the ride heigth down as much as possible
854RUN
well if your ok with trimming your fender to fit 40's go with 5" or 6" in the back and 2" or 3" in the front and that will keep you low. I need to trim my rear fenders from the bottom about 6" up but not by much maybe a 1/2" on each side of the fender.
-JOSH-
Toyin
Went out and did some measurement and i don't know if i can get it out of my garage door. It's only 7'. As far as hangers i'm going to build my own front and use the sky tacoma shackles for the front shackle hanger. Rears are going to be frenched datin fab. I need to put an order in for my axle swap parts from ruff stuff. Hopefull if things go right i can order everything the 22nd
854RUN
sounds good keep us in the loop, o and lots of pic :)
-JOSH-
jpharper33
I really like your truck.  By chance, would you happen to have the alternator connector that you cut off your truck to install the bigger alternator?  Just so happens, it is the same connector I need to get my DD back on the road, a 98 taco.  PM me or reply if you do.  Sorry for the hyjack but I can't PM yet I think until I get my post count up. (sorry for the newbiness)
854RUN
well yes and no. i did not cut the wires, just removed them with the pins and put them in the new plug. So all i have is the old plug with no wiring. I am more than willing to send you the plug if that will help you but like i said no wires.
ps don't worry about the hyjack this is about my truck and what i do with it, and if that involves helping you well then no hyjack :)
pm sent
-JOSH-
<MIKE>
Awesome Rig man.. i love seein those T's swapped and put to use. There is one close by me that looks very similar and i've always drooled over it. I liked your remedy for keeping the tie downs on the bob job. First i have ever seen like that. Doing mine in the next week or two.
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89's
249:1
854RUN
Thanks man, looks like you have a sweet taco. one day i would love a d-cab taco. You going to try and keep the pockets when you do yours?
I like how it keeps it "factory" looking and functional.
-JOSH-
<MIKE>
 Thanks man. Ya i love my taco i just built it this past summer. i have had it for 6 years. i honestly have never thought about that until yours.. its deffinitly worth checking out now
1987 4runner
249:1
854RUN
R151 to 3.4l swap  :biggthumpup:
So I finally swapped out my tranny for my r151 and duals!! Well I kind had no choice the stock tranny 341xxx miles on it and went from sounding like a coffee grinder to a tin can with marbles in it. This was not as easy as I thought it was going to be.
This swap could have been easy if I had stock exhaust manifolds (from what little info I have found on the swap) but I have JBA headers. The issue is that the header collector on the passenger side hugs the stock bell housing. Now in order to do the swap you need to put a bell for the 3.0l on the R151 and that has the same bolt pattern as both engine and tranny. The issue with the 3.0 bell vs. the 3.4l bell is that the clutch fork goes from the wide open driver side one the 3.4 to the cramped side on the 3.0 witch if you have JBA headers the passenger side needs to be pushed out 2" to clear the fork and slave. After trying to figure out what to do besides cutting up my $700 headers I cut them :rivers:. I cut them about a quarter of an inch from the flange and added 2" then put them back on. From there I re-did the driver side drop down pipe (the peace the drops down from the cross over). The other pain in the butt is that the shifter comes in the cab about 6" to 7" in front of the stock tranny.  Fixed that mess with a 7" dog leg!! And a 4" dog leg for the reductions box shifter (only because I have it set up as a forward shift). I can now leave my arm on the arm rest and shift in all gears lol. The t-case just needed a new hole about 2" to 3" back from the original floor opening for the shifter. X-member is still stock but it just about bolted right up. I had to cut the center out and weld it back in place a ½" up and ½" forward. Now I need a new front d-shaft and a new rear d-shaft some day, I cut 6" out of the rear and have been running it for a couple day at 75 to 80 mph with no vibes so it can wait for now.  O and as far as the clutch goes I used Marlins HD 1200ftlb clutch for a 3.4 and a 3.0 throw out bearing.  I will take some pic up and post them. I did not take any over the weekend when I was swapping it.
-JOSH-
P-DiseToy24
Sounds like a pain in the ass.  Glad to hear you got the duals in your gunna love um.
yotaneck13
did the same swap in my 95 t100 and its no different with the stock manifolds my y pipe wouldnt clear the bottom of the tranny so it now y's to gether on the carrier berring crossmember... well it did mine is im pieces gettn new suspension and a full build
854RUN
Quote from: yotaneck13 on June 03, 2010, 12:35:37 PM
ya were the two side meet into one is right at the cat and that right above my shackle. i had to re-do it about 3 times, i moved the cat 6" back totally out of the way of the shackle. That was the worst and most time consuming part of the swap by far.
-JOSH-
yotaneck13
how did you get the crossmember to bolt up? i had to cut the center out of it and weld new mounting plates to it
854RUN
ok pics
-JOSH-
854RUN
exhaust
-JOSH-
854RUN
and
1 rear d-shaft
2 shifters
3 6" dog leg
4/5 new front bumper
-JOSH-
46&2
muddytaco
yea that thing is sweet, my wifes little brother stole my t100 and blew the motor up
95 tacoma 5" revtek/bilstein detroit locked 9" with drilled and slotted rotors front and back, 8000# mile marker winch, 16" crager crawlers, too much other crap to mention
96 t100 2wd (soon to be sasd i hope) - dead
85 efi 4runner
01 sequoia
854RUN
Thanks guys
that suck sorry to hear man did you kick his ace
-JOSH-
muddytaco
no theyre the kind of ppl that it would cause me alot more trouble in the end, ive got other trucks, plus he says hes gonna pay me back, and he already tried to give me a little but id rather have it all at once, anyways nice truck man lol
85 efi 4runner
01 sequoia
854RUN
#115
well getting about that time to get new tires. So i put some TSL 38.5x16xr16.5 (121lbs each :o) that i have laying around to see what they would be like. Just a little to wide, but if i ever wont to go muddin lol
-JOSH-
toyreb
I heard there's extra wiring involved with putting a supercharger on a 95 T100, can anyone confirm of deny?
854RUN
Quote from: toyreb on September 21, 2010, 07:19:13 PM
dont know about the 95, i do know the ecu is not really setup for a s/c and has issues. TRD will tell you that you can not do it, they changed the ecu in 97. you might be able to swap it but i am not 100% on that. this is a good sit to look at for more s/c info: http://www.gadgetonline.com/Super.htm
i would also say to give a call to URD they will tell you yes you can or no you cant. I've heard of guy pulling it off with the help of this kit from URD http://www.urdusa.com/product_info.php?cPath=1_3&products_id=1230100017
Good luck
Josh
-JOSH-
hotshoe
Quick question regarding your truck. Did you have to do any pinion angle correction with the shackles under the frame? Cut and turn, spring perch wedges etc. Love the truck and gathering ideas and suggestions for my 97 T100 that is under the knife.
Thanks
97 T100 Under the knife!
P-DiseToy24
You can also build a bigger or smaller shackle to change the angle.  Moving the solid mounting point of the leaf spring will also change the angle.
