Hi i am deaf and some problem with english.. so My truck keeps roughing after warm up like when i start it in the morning and drive it and run really smooth... few mins later like 5 to 15 mins, it started roughing pretty bad also when i turn it off after smooth then turn it on. it roughs awful. i replaced the spark plugs, coil, distributor,and rotor cap and checked fuses , amps and vaccum hoses no leak , adjust the timing and all compressor are 180psi are good... it is still the same problem.. i have no idea whats wrong with it.. could be oxygen sensor? throtther body? does anyone knows about why it has the problem? pls help me,, thk u very much..
Joel
