Author Topic: Lockers - ARB or Electric?  (Read 2000 times)
EricCartman
  • Member since Jul '07
« on: Jul 03, 2007, 09:59:12 AM »
Hi All,
I've come to the point where I am thinking about doing lockers...  I'm pretty sure I want to get a selectable locker.  So that leaves pretty much ARB or Toyota E-lockers.
There are several things I like about the Toyota e-lockers...  such as being factory parts and they can be manually operated if needed.  The part that I don't like so much - is the welding/drilling/tapping to my existing housing to get these to fit.
The ARBs seems quite nice too - since they are fast to engauge and I don't have to do any modification to the axle housings.  The only thing that makes me a little leary is that this is controlled by air.  I would think eventually a seal could fail and that would be the end of it.  I have not read any posts about this happening... but I suppose it could.
My plan was to buy the complete 3rd members from Marlin - and do the install myself.  This can be easily done with the ARB option - but the e-locker would be a bit more difficult.  I would have to pull the axle housing and get the machine work done at a competent shop.
What do you all think?  Would it be worth the hassle to pull the axle housings out to get the machine work done and a shop so that I could have e-lockers?
Thanks,
Cartman
red
  • Turtle Points: 199
  • Male Posts: 1,616
  • Member since Jan '05
Re: Lockers - ARB or Electric?
« Reply #1 on: Jul 03, 2007, 11:24:37 AM »
really it comes down to preference. the arb company has not had an actual locker fail, but if you run the lines incorrectly you can have a line fail (run it too close to the exhaust, run it so the line can bind up/break, etc...). but, with the arb you also get a compressor so you can air up your tires after a trail ride.
e locker is more of a pain to set up as you mentioned but doesnt have the potential problems of installing the lines incorrectly.
read and comment :whip:
USAF EOD tech
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Colorado Rocks!
    • http://www.rockfrogs.org
« Reply #2 on: Jul 03, 2007, 12:14:21 PM »
I think both are great lockers.  What I don't like about the E locker is the engagement time.  Sometimes they engage right away, other times it can take 5-10 seconds.  With the ARB, it's instant.  My brother has been running ARB's F&R in his YJ for over 2 years, no problems at all.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
~tc~
  • Male Posts: 143
  • Member since Apr '07
« Reply #3 on: Jul 03, 2007, 05:52:25 PM »
99.99999% of the problems with ARB's are installation related.
I priced out both options, and if you want any degree of on-board air the ARB route is cheaper.
'93 4Runner, V6/MT ARB's, armor, 33's, no lift!
President, CO Chapter TTORA www.cottora.org
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #4 on: Jul 04, 2007, 03:45:39 PM »
I prefer ARB's because of how fast the lockup compared to the e-locker. Either one are good. The two problems I have had in ten years of running them both have been installer error.
As far as using the ARB compressor as OBA, I would not do it. It wearsthe compressor out prematurely. First five years I had mine in I used it and I had to rebuild the pump part. Cost was only thirty dollars  for a complete kit but the bad part was it started leaking bad on a Con run.
TurtleTappers91
  • Turtle Points: -5
  • Male Posts: 310
  • Member since Mar '07
  • ..I walks me a mudhole and I stomps it dry... baby
« Reply #5 on: Jul 04, 2007, 07:56:16 PM »
The ARB is cool because you can lock it up on the fly. It works well. The mini compressors are nice too, pretty reliable...
I have had two air line breaks, I think the blue plastic air hose is the weak link, I'v seen some beefy brake line style replacement hose for sale, but it is big $$$
OOPS
  • Male Posts: 2,561
« Reply #6 on: Jul 04, 2007, 09:52:46 PM »
I have been running the same blue line on the rear for ten years.
TurtleTappers91
  • Turtle Points: -5
  • Male Posts: 310
« Reply #7 on: Jul 04, 2007, 11:00:15 PM »
The air lines can snag tree branches and crap when bushwackin'
It all depends on what your gonna do with it I guess... :twocents:
EricCartman [OP]
« Reply #8 on: Jul 06, 2007, 10:25:50 AM »
Cool... thanks for all the input.  It sounds like either way is good will be just as good.  Now I just need to scratch up some coin. :)
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • Member since Dec '05
  • California livin'
« Reply #9 on: Jul 06, 2007, 10:33:16 AM »
X2. I am going to go with an ARB when i can afford it. Wanted toyota E lockers but a few people have told me they fried theirs going through a lot of deep water repeatedly. where I live there is no end to the deep water so i cant have a locker that may potentialy get disabled by moisture.
Rockcrawlintoy
  • 4 doors for more whores
  • Turtle Points: 2147
  • Male Posts: 2,339
  • RIP Kyle
« Reply #10 on: Jul 06, 2007, 10:49:33 AM »
if u run the lines correctly you wont have this problem also u can use the heavy duty air lines which are much better.
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Last post Aug 03, 2004, 11:07:01 PM
by To The Floor
Last post Apr 12, 2009, 10:45:48 PM
by sandboxtoy
Last post Jul 06, 2009, 11:32:11 AM
by hilux-1983
Last post Sep 09, 2010, 07:54:39 PM
by Snowtoy
Last post Jan 01, 2021, 03:40:52 PM
by Djencee
